cant start when I depress clutch pedal
Old 06-23-2012, 09:34 PM
c0y0ta's Avatar
Originally Posted by TrikeKid
shift without the clutch, once you get a feel for it and get used to rev matching shifting 1-5 and back down without the clutch is cake.
Can a person learn to do this without destroying much or is it way wiser to learn on a beater about to be scrapped?
The other question I had is the clutch start cancel switch - is its light supposed to remain on if you've used it to start with? Mine does and it makes me think something is wrong.
Old 06-23-2012, 10:20 PM
ChefYota4x4's Avatar
Mine is the same, and I'm pretty sure once you use it to start the truck, it's supposed to/it's normal to stay lit until the next time you turn the key to off and then on again.
Old 06-24-2012, 02:35 AM
RAD4Runner's Avatar
Originally Posted by Kiroshu
Its actually better to start a manual vehicle with the cancel switch.
Above is only OK if one makes it a habit to check that transmission is in neutral before activating Clutch Safety Cancel switch, because many drivers park trucks in first gear for additional parking braking. I realized this, because I used to activate safety cancel for weeks in order to troubleshoot my intermittent no crank issue. One day, I took truck to shop for maintenance work. When I got in and started, using safety cancel as a habit, truck "jumped" because mech had appropriately parked it in first gear. Fortunately, there was nothing in front
Correct, Chef. Safety Cancel has "holding" circuit. It will stay active until you turn off ignition.
Old 06-24-2012, 07:35 AM
c0y0ta's Avatar
why???
Old 06-24-2012, 07:45 AM
  #25
89yota22repower's Avatar
I just washed my yota.. and now it wont start. i get power and what not. go to turn over and it just clicks. will not start. i use the clutch petal, and clutch start cancel, IS it starter do you guys think? let me know thanks.
Old 06-24-2012, 08:46 PM
  #26
nothingbetter's Avatar
It real easy to do. Going up in gears is easy just pull the shifter where you want it to go and apply steady pressure on the stick. Once the engine drops to the right rpm it will drop right in. You have to be pretty quick for some gears though. For down shifting you just have to rev the engine in between gears so it, once again, hits the right rpm level and the transmission drops into gear. All you can do is try! It is possible to drive a standard without using a clutch pedal, even from a stand still.
Old 06-24-2012, 09:45 PM
  #27
RAD4Runner's Avatar
why???
Not really sure why there is a holding circuit, but I believe it's for certain situations where you need to start the truck while in gear. For example, when truck is facing uphill with its rear wheels too close to the edge of the road with a drop off. You'd want to start it while it's in gear. Wheelers may be able to confirm.
smthwsn357
05-01-2024 07:28 AM
mskalmus
05-28-2017 07:51 AM
Kalihi,HI
07-09-2015 04:29 PM
raiderhawks00
07-08-2015 06:23 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: cant start when I depress clutch pedal
