Bouncing Battery (Voltage) Indicator
Old 08-06-2013, 01:42 PM
Alaska90's Avatar
Hello,
1990 v6 4WD with replacement, non-OEMm, alternator.
Four or five years ago I had my alternator die on a lonely stretch of the Alaskan Highway. They only part available was a non-OEM, so went with that.
Lately I've noticed the Battery Indicator's needle is bouncing around instead of being steady. Its on the upper end of the scale. It doesn't always bounce but i have not been able to assign any relationship to its bouncing to any other thing.
I checked the belt, its fine.
Is this a sign of worse to come? Any idea on what could the cause?
Thanks.
Old 08-06-2013, 02:04 PM
wyoming9's Avatar
Red face
Have you measured the voltage at the battery while at a high idle.
Could be a gauge going out
or the voltage regulator.
Or just a loose connection any place in the electrical system
Pretty much have to troubleshoot one thing at a time.
If it is the voltage regulator the worst that can really happen is you cook the battery it can get quite hot I have never had it happen but dirty oiled engine compartments could ignite or else it just fails and no output.
Old 08-06-2013, 04:57 PM
scope103's Avatar
Check the voltage at the battery, pronto. Even without it getting hot enough to ignite something (!!), over-voltage will kill the battery pretty quickly.
http://www.harborfreight.com/catalog...t?q=multimeter
Bourbonblues
12-15-2017 05:43 PM
Marley2984
12-06-2015 05:19 AM
Longbed 90
10-19-2015 11:05 AM
tazman1972
11
09-28-2015 10:32 PM
SCZIG
09-20-2015 09:00 AM
Quick Reply: Bouncing Battery (Voltage) Indicator
