Bleeder-Dude's Official 22re Engine Rebuild Thread - TONS OF PICTURES!!!
Old 05-04-2009, 08:32 PM
  #41
874runnersr5's Avatar
more pics super!
Old 05-04-2009, 08:42 PM
  #42
iamsuperbleeder's Avatar
Originally Posted by TOYOTA 1
porn for days!
good pics..
ohh and bleeder, please tell me your not going to seal the valve cover on the new motor like its done on that one there.
lmao, no I'm not
that was from taking the valve cover off and finding a broken driver's side timing chain guide a little while back; I didn't want to waste the bux for a new one since the master rebuild kit will come with a new one, and it only needed to hold for another week or 2, so just to make sure the old one sealed up, I added a "little" RTV
Old 05-04-2009, 08:43 PM
  #43
Originally Posted by 874runnersr5
more pics super!
more gmod 4runner! WTH have you been man? lol
Old 05-04-2009, 08:53 PM
  #44
BLKNBLU's Avatar
I'm kinda late to the game but consider something other than black for the engine block and under hood area. That way if you have something leaking you will:
a) notice it sooner
b) be able to trace it more easily
On the other hand, it's your engine, so do what you want. Just food for thought. Good luck.
Old 05-05-2009, 05:08 PM
  #45
Wohoo, day 3, and a since of real accomplishment
The motor's ready to be yanked out! I'm going to my buddy's house right after work tomorrow to pick up his hoist, then coming home, and I'll have this thing pulled about 30 minutes later!
removed all the bellhousing bolts, and one of the motor mounts on each side; all that I have to do is remove the 2 last loosly-fitted motor mount bolts, and she should wiggle right out
lemme tell ya, those two bellhousing bolts behind the head, are a PITA!!! a little easier without the intake manifold in the way though, lol
and of caurse, the parts pile is getting EVER LARGER, lmao
One quick question for you guys though. Is an impact gun the ONLY way to get the center crank bolt loose? I've tried the 4wd-low range with a 2ft cheater bar, and the truck just keeps climbing over whatever block I put against the tire, lmao it's standard thread too, correct? not reverse thread?
a) notice it sooner
I thought about that too, but that's why I'm using the undercoating stuff, so it's kinda a dull-flat look, and a leak should stand out on it as being a bit more shiny than the surrounding area; I least that's my assumption
Old 05-05-2009, 05:22 PM
  #46
toyota4x4907's Avatar
/me twitches because of the pile of stuff just piled together...not organized....
Old 05-05-2009, 05:25 PM
  #47
lol, man I gotta to through EVERYTHING and clean and paint stuff, so I'm not at all worried about it
Old 05-05-2009, 05:34 PM
  #48
looks good super, cant wait to see more.
go on steam
Old 05-05-2009, 05:41 PM
  #49
d71889b's Avatar
man your header is soo clean. my whole exhaust is almost rotted out..already
its not even worth painting
Old 05-05-2009, 06:17 PM
  #50
RMA
RMA's Avatar
Bleeder , what are you doing online shouldnt you be outside taking pictures.
Old 05-05-2009, 07:03 PM
  #51
toylocost's Avatar
Location: Yotatech, because Pirate is too expensive. NorCal.
I always put the cheater bar on it and put it up to that frame and tap the starter. But its a little late for that one. lol
Old 05-05-2009, 07:10 PM
  #52
lol, uh yeah
lmao what else is there to take pictures of at this point?
oh there will be many more tomorrow, when I pull the thing out
I thought it looked pretty bad too me cause it's not really that old... but a little sanding and a few coats of silver header paint should have it in brand new condition
Old 05-05-2009, 07:35 PM
  #53
BigBluePile's Avatar
nice header...
About the crank bolt. I always jam the brake pedal to the floor and hold it there with a piece of wood against that rise where the front seat bolts. Then put the tranny in fifth gear. May as well put the ebrake on too if it even works. Now, you have four wheels and the tranny locked up. Now use a cheater pipe on a breaker bar a pop that bolt loose.
Note to the rest: make sure to break the crank bolt loose at the first available chance. bleeder seriously, I'm looking for the face/palm pic right now...
Old 05-05-2009, 07:46 PM
  #54
TOYOTA 1's Avatar
no, its a normal right hand threaded bolt.
also you want to be in 5th gear high range with the ebrake on, not low range edit.. bbp beat me to it.
and what up with the mangled heater core ends?
Old 05-05-2009, 07:49 PM
  #55
scuba's Avatar
FOUND IT !!
hah, trav it looks like a fun time.
I too think it wouldnt be fun to paint the engine bay black, just my opinion..
Good luck man !!
Old 05-05-2009, 08:10 PM
  #56
86Toyrunna's Avatar
im doing this same project to my runner right now also.. except iv got a reman motor to just swap in. as for the crank bolt.. ya i forgot about it till after i had my motor out sittin on the ground. i took a good sized drift and a 2lb hammer and wacked the bolt a few times to break loose any locktite or possible rust and then hit it with my 1/2 drive impact gun. she came right off..even with green locktite... might i give u a word of wisdom tho, if you are planing to clean you EGR valve and tubes.. maybe try not to take the upper tube off the vlave were they screw togeather.. i just broke mine today.. gotta try and weld it back togeather.
Old 05-05-2009, 08:16 PM
  #57
wheatus's Avatar
i am a fan of painting the engine bay black because
1. it looks good
2. if you ever decide you want a new color the bay will match anything
3. it looks good
4. it hides all the nastiness that tends to accumulate
5. best time for a little corrosion protection on the fire wall and inner fenders
6. if you paint the block it will really pop in a black engine bay
7. wiring and hoses just aren't as noticable
8. leaks are easy to find on semi-gloss or satin
9. one more custom touch
10. it just looks good
Old 05-05-2009, 08:27 PM
  #58
nice header...
well the motor's still in, and the clutch is still engaged, so I'm going to definately do that tomorrow before I pull the motor
yeah I don't know why I was thinking low range 1st gear was the right gear to do that in, lol now that I think about it, that's the most useless gear to try that in, lmao
the mangled heater core ends, well, just after this winter, my heater core developed a leak, so I just pulled the hoses off at the firewall and looped it to bypass the heater core, and I somehow managed to do that to each end of the outlets
1. it looks good
3. it looks good
haha, sweet deal, thanks!
do you think it'll be too much black if I do the block in black, in a black engine bay?
that's got me re-thinking my color choises now of the block, not the engine bay
Old 05-05-2009, 08:30 PM
  #59
Ah Scuba!! What would we do without you!!! LOL!!!!
bleeder, looks great man!! Can't wait to see the "guts" of the project!
Old 05-05-2009, 08:32 PM
  #60
lmao, yeah, thanks Scub for bring facepalm into my build thread
thanks Blue, me as well; hell I cant wait just to start putting clean parts back together
Quick Reply: Bleeder-Dude's Official 22re Engine Rebuild Thread - TONS OF PICTURES!!!
