backfiring/hesitation/cuttin out
Old 03-13-2009, 12:36 PM
bagged94yota's Avatar
Exclamation backfiring/hesitation/cuttin out
i have a 94 yota and when i drive it, it backfires and doesn't want to go. i had it in 2nd gear the other day floored and i was only doin 20mph. sometimes it smells rich and it idles really funny. ive already done a new tune up and changed the fuel filter and tried a new maf. could be my valves 2 tight or somethin with fuel? help me out plz.
Old 03-15-2009, 08:34 AM
spitfiremkiii's Avatar
Any engine codes?
Old 03-22-2009, 11:43 AM
no it don't
Old 03-22-2009, 01:45 PM
Robert m's Avatar
have you checked your AFM? i had mine go out on me last week and it was doing alot of the same things you have described.
my dads friend who is a mechanic showed me an easy way to check them. just pop open the air box while its idling and use your finger to push open the flapper. the truck should stall out right away. if it doesnt stall and keeps running then something is wrong with it and you should replace it.
Old 03-22-2009, 02:14 PM
ahickman's Avatar
Timing is way off? Did you have the distributor out recently?
Old 03-22-2009, 03:57 PM
yodercrawler55's Avatar
if its fuel injected it could be injector problems
Old 04-01-2009, 04:17 PM
DupermanDave's Avatar
any updates?
Old 04-12-2009, 01:25 AM
SurfingDrunk's Avatar
seafoam!
Old 04-14-2009, 05:04 PM
ill check those. how do i tell if my injectors are bad? its not my timin ive set it twice. thanks for the tips if yall think of ne thing else hit me up.
Old 04-14-2009, 05:31 PM
abecedarian's Avatar
pull your trouble codes. if it's running that bad, you've probably thrown at least one
-but based on the 411 above igniter.
Old 04-14-2009, 08:51 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Maybe 1 or both of the o2 sensors? I don't know if the '94 had 2 or not. Just kind of a thought.
Old 05-03-2009, 06:03 PM
well the other day i cranked my truck and it died n i seen smoke comin out of the mafs. it smelled just like gas, ne body kno what that cld b?
Old 05-03-2009, 06:43 PM
Lummpus's Avatar
you said you recently did a tune up. Are you sure your firing order is correct?
Old 05-03-2009, 07:54 PM
yzrider273's Avatar
you might have a vacume leak....in the intake manifold
Old 05-03-2009, 07:56 PM
Sin91's Avatar
timng not right or valves
Old 05-04-2009, 02:54 PM
the timin is good and i have the firin order right. thanx for the advice if ne body can think of somethin else let me kno its helpin alot
Old 05-04-2009, 03:01 PM
1stgen4gunner's Avatar
check to make sure you sparks are plugged into the correct part of the distributor, what I would do is remove you distributor cap and make sure there is no moisture and take all the wires and makes sure they are plugged in correctly.
Old 01-22-2015, 09:12 AM
Kalihi,HI's Avatar
Aloha from Hawaii. Did you ever figure out your backfire issue? I got a 94 3.0 with a bad backfire (or after fire) when decelerating, it's so loud it sounds like a gunshot...I deleted my cat and just got a new walker sound fx muffler (it's what the truck had when I bought it), but I notice some leaking exhaust in my exhaust pipe (rusted holes) leading up to my muffler. Could this cause the backfire? Thank you for any help.
