Auto to Manual wiring help
Old 08-01-2012, 01:11 PM
4runnerlover95's Avatar
Well I'd start by figuring out the ignitor coil problem... That's where I would start and see what you can find
Old 08-01-2012, 01:24 PM
3slow's Avatar
Well my friend may have another coil i can test on his truck that does run & i'll find out what readings i get on it but the only thing i'm concerned with is that his is a 90-91 & i do believe they are a different coil & ignitor unit.
Old 08-09-2012, 01:38 PM
prickelsworth's Avatar
Will a MT ecu just plug and play so to speak?
Old 08-09-2012, 01:44 PM
I am also doing the swap. 91 auto to 93 manual. I have a complete donor 4Runner. Keep reading that everyone just uses the auto ecu. I have the manual ecu and just want Somone to say, oh yea, just plug in the MT Ecu.
Old 08-09-2012, 02:34 PM
  #25
SacRunner's Avatar
Based on the EWD (Electronic Wiring Diagrams) for a '91 3VZ, it looks like it should work; there's only one set of ECU connectors and pin numbers listed regardless of M/T or A/T (unlike a 96 5VZ which has different connectors and pin numbers for M/T vs. A/T). The only gotcha I saw, I didn't look too closely, is that you'll need to short the "Neutral Start Switch" (most likely plugged into the auto transmission, has a black wire on one side and a black with white stripe on the other) to allow the starting circuit to close properly; the M/T used a switch on the clutch pedal to engage a relay that closed a similar circuit between the ignition switch and ECU and starter.
These should help:
http://www.ncttora.com/fsm/1990-1995...es/wiring.html
http://www.ncttora.com/fsm/1990-1995...emci/eng3r.pdf
Old 08-09-2012, 09:25 PM
  #26
Thanks for the reply I appreciate your time and effort.
Old 02-28-2021, 03:41 PM
  #27
Weston Muir's Avatar
So I’ve got one question, not related to the Toyota, but I’m doing a 5.0 swap into my Ford ranger, I can’t find a manual ecu with 4x4 so would I be able to just use the auto ecu
Old 03-01-2021, 06:14 AM
  #28
MaK92-4RnR's Avatar
david braun
3.4 Swaps
15
01-15-2013 05:21 PM
JTonJuice
3.4 Swaps
11
08-30-2012 11:06 PM
Swimmerboy2112
3.4 Swaps
04-12-2011 05:30 PM
stockwell45
3.4 Swaps
14
06-29-2010 12:07 PM
AMSeiple
13
02-08-2005 05:42 AM
Quick Reply: Auto to Manual wiring help
