Auto to Manual Help!! Starting...
Old 06-12-2012, 09:10 AM
4runnerlover95's Avatar
Okay, so Ive been posting awhile now about help with the wiring and stuff for the auto to manual swap in my 1995 4runner V6. I really need some help. Yesterday was the first day i tried to start it after replacing the heads and swapping tranny's. When I go to start it, it cranks but won't start. We tried hitting it with the timing light while cranking and came up that there is no spark. So somewhere from my ECM to ignitor there is a signal to not send any spark.... I have one plug that I don't know where it goes ( At this point I think it might be an extra from the manual swap) but it is from the wiring harness near cylinder 6 in the back almost by the coolant bypass system. (In picture). If anyone knows where it goes that'd be great. Furthermore, I only spliced the two black wires together. (YEs I know I can start it in gear this way. I am completely fine with that fact). ANything to help me get this thing running id appreciate... after 2 months im dying to hear the sound of that engine!
Attached Thumbnails Auto to Manual Help!! Starting...-photo-1-.jpg   Auto to Manual Help!! Starting...-photo-2-.jpg
Old 06-12-2012, 09:14 AM
Also I know I dont have the reverse lights hooked up as they are smoked and barley work as is and I have other lights that I attached and manually turn on. ANother thing is I dont have my speedometer cable hooked up; would that prevent it from starting?
Old 06-12-2012, 12:10 PM
93toyrunner2's Avatar
Pic #2
Coolant temperature switch located behind plenum on the sensor block, or knock sensor connector located coming out of intake just in front of #6 cylinder fuel injector, or a fuel injector connector. It is hard to tell from your image, how many pins in the connector? what color wiring on each pin?
http://www.ncttora.com/FSM/1990-1995...emci/eng3r.pdf
Old 06-12-2012, 12:20 PM
I think it is for the coolant sensor.. It is grey cover with 2 pin connectors that are both yellow
Old 06-13-2012, 04:24 AM
What color are the wires coming out of the sensor?
Old 06-13-2012, 12:04 PM
The connector wires goin into the plug are green and a black with orange wire
Old 06-13-2012, 12:49 PM
anthony1's Avatar
Did you change the ECU to manual?
There are conditions that has to be right inorder to start in both manual ecu and auto ecu. If you're still using auto ecu then I'd look at the park/neutral switch...or something along those line....
Old 06-13-2012, 01:01 PM
The engine coolant temperature sensor has a Green w/ Lima (blue) stripe and a Brown with Black Stripe.
Fuel Injectors are Brown w/ Red Stripe and either White w/Red or solid white depending on the side of the engine.
Cold Start Injector Switch has Green solid only.
http://www.ncttora.com/FSM/1990-1995...e/overalle.pdf
Old 06-13-2012, 01:05 PM
I didn't change the ecu. Almost all of the write-ups I have read, most don't switch ecu
Old 06-13-2012, 03:00 PM
justin_4runner's Avatar
do u have the ground wire from the plenum to back fire wall and another one on drivers side fender well to head?
Old 06-13-2012, 03:12 PM
I'm not sure where you are talking about for the plenum to back firewall... But the drivers side fender to head is grounded.
Old 06-13-2012, 03:27 PM
there also should be a ground from the back fire wall about the middle and bolts to the upper plentum at the back edge facing the firewall.
also 4runner where u live? might be someone close by that can give u a hand figuring out ur problem.
Old 06-13-2012, 03:30 PM
Yea I have that grounded. I've just spent 3 hours tracing the wiring harness with no results. I don't know what to say...
Old 06-13-2012, 03:32 PM
I'm from Seattle, WA. I know there are lots of resources around, this one is just stumping me
Old 06-13-2012, 03:34 PM
im in the tacoma area and if u get to the point that u need help let me know i can swing by some time and give ya a hand.
Old 06-13-2012, 03:37 PM
Thanks! I appreciate that. If I don't figure this out soon I'll take you up on that!
Old 06-13-2012, 06:14 PM
so i was thinking about it and have u looked at ur dist? is it hooked up? have u tested the distributor and coil to make sure there good? depending on what coil and ignition box it has i do have an extra that i cant use,
Old 06-23-2012, 12:13 PM
I got it running!! Turns out the mass air flow was bad... Put in a manual ecu and new sensor and she runs great! Such a relief to finally have it run again!! Thanks for all the input guys
AndYota
08-10-2015 09:19 AM
jbandt
08-03-2015 03:23 PM
TransAmBandit
07-28-2015 11:30 PM
Sandman
07-14-2015 12:36 PM
KBar
07-13-2015 06:01 PM
Quick Reply: Auto to Manual Help!! Starting...
