alternative to clutch pedal
Old 06-18-2009, 11:48 AM
Robert m's Avatar
if this is going to be your first time building something with no instructions then the project should not be reinventing the wheel when it doesnt need to be done. now i can understand wanting to do something different and new and challenge yourself but vehicle manufactures have already conquered this task by making auto transmissions. why go through the headache, hassle, time, and money to do something that has already been done and perfected? many people have gone the other direction from auto to manual so doing the opposite shouldnt be much more difficult. hell, you might find someone in your area that is willing to swap you for your stuff and save you a good amount of money.
Old 06-18-2009, 11:56 AM
toylocost's Avatar
Location: Yotatech, because Pirate is too expensive. NorCal.
I found the pirate thread. Idk if they found anything I didnt read the whole thing.
http://pirate4x4.com/forum/showthread.php?t=795192
Old 06-18-2009, 12:19 PM
DupermanDave's Avatar
It's not my first time, I was making a small joke. I've done lots of electrical and machine engineering projects. Just nothing complex like this.
Old 06-18-2009, 12:28 PM
habanero's Avatar
Originally Posted by Stuwy123
Then you would have one beefy forearm from holding the clutch in. Well maybe you already have one beefy forearm from another "hobby"...
are you saying ol' Popeye was ambidextrous?
Old 06-18-2009, 01:46 PM
  #25
Flash319's Avatar
Easy,
LVDT (analog) style button + stepper motor controller + ballscrew + stepper motor (maybe a gear box) = electric clutch. How does $1000 sound?
Or $100 automatic trans............
Old 06-18-2009, 02:58 PM
  #26
Originally Posted by Flash319
Easy,
If I could find a $100 auto tranny....i'd prefer that route. But everyone where i live has stick.
Old 06-18-2009, 03:30 PM
  #27
modlite's Avatar
Technically you're just balancing your legs out. You're putting strain on your knees lifting off the throttle and hitting the brakes too.
Old 06-18-2009, 03:49 PM
  #28
Flash319's Avatar
I got one I will sell ya for $100. You gotta come get it though.....
Old 06-18-2009, 04:07 PM
  #29
The trip alone would make the tranny cost $500
Old 06-18-2009, 08:34 PM
  #30
aviator's Avatar
Slushboxes are for wimps Real men and women drive stick, whatever it takes... besides stick is better in the mountains and for fuel econ.
Have the motorcycle lever cable attached to the control lever for a hydrolic ram attached to the clutch master. The force feedback through the ram/lever should allow you to feel when the clutch engages and allow you to slip it when needed as long as the cable is set tight enough. Basically the same idea as the hydolic feedback feel on a backhoe/excavator.
Old 06-19-2009, 07:52 AM
  #31
Alex 400's Avatar
to make it even easier, you could use a universal hydraulic motorcycle clutch that would attach to the old chunk of the clutch pedal that would operate the stock master cylinder. There is a multitude of ways to make this easier, the difference here is that you are trying open a clutch with 900 pounds of shutting force or more (depending on the clutch) you would need a long lever.
have you tried pushing the clutch by hand? let alone using your grip to pull the clutch in? also look at how long the lever is that your leg is using to pull the clutch in with an hydraulic system, which can make it easier too. I am still kind of wondering why? do you have an injury and don't want it to flare up again, or something? the only things that i see reasonable on shifters, are gear spitters, jake brakes, and throttles. if you don't want to do the clutch with your foot, get an auto. to get the same power from your grip that your leg was exerting, would almost impossible with out a really long lever on the motorcycle grip that i don't think you would be able to get your hand around.
good luck with whatever you do.
alex
Old 06-19-2009, 09:20 AM
  #32
you "switch to an automatic" guys take all the fun out of it.
I'm still looking online for an auto transmission I can swap in, but in the meantime I'm also looking for parts to do this project. Whichever I find first I'll go with.
akamon808
3.4 Swaps
12-16-2015 08:45 PM
ManzDaKlown24
08-22-2015 10:25 PM
duncanmc
08-19-2015 03:13 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
Kalihi,HI
07-09-2015 04:29 PM
Quick Reply: alternative to clutch pedal
