94 Pickup Knock Sensor Pigtail Ground
Old 07-06-2011, 10:45 AM
elaketiger's Avatar
Does the knock sensor pigtail ground wire (shielding) attach to the engine block in any way? There are two wires from the pigtail connector: one goes to the knock sensor pin and the other is the shielding. Does the shielding connect to anything at the end or does it just run to the end of the pigtail (near the knock sensor) and stop?
Old 07-06-2011, 10:49 AM
TNRabbit's Avatar
It should be grounded internally to the knock sensor & the wiring harness on the other end.
Old 07-06-2011, 10:53 AM
elaketiger's Avatar
Do you mean that when you plug it into the knock sensor it makes a contact from both wires (inner wire and outer shielding)? And, then the knock sensor threading into the block complete the ground?
Old 07-06-2011, 04:41 PM
TNRabbit's Avatar
That would be the common wiring for an outer shielded wire.
Old 07-06-2011, 05:13 PM
MudHippy's Avatar
Yes, that's exactly what it does(most of the time, if anything, much like a coax cable for your tv in construction). It does not connect to the sensor or block. So it's a shielding, NOT a ground, wire (mainly). There's a distinction between the two, and/or those that are both. In this case we are talking about the E1(engine ground) and E2(sensor ground) circuits. This sensor wire is shielded it's entire length, but the shielding is only connected to the E2(Sensor common ground to ECU) circuit at the ECU wiring harness end.
However, I believe the design isn't necessarily intended for shielding purposes though, but rather in case the sensor wire breaks. That way it would atleast have a chance of grounding itself to E2(possibly semi-permanently), and not continually arcing on the other wire stub and/or the engine block/E1 circuit.
A shielded or screened cable is an electrical cable of one or more insulated conductors enclosed by a common conductive layer. The shield may be composed of braided strands of copper (or other metal), a non-braided spiral winding of copper tape, or a layer of conducting polymer. Usually, this shield is covered with a jacket. The shield acts as a Faraday cage to reduce electrical noise from affecting the signals, and to reduce electromagnetic radiation that may interfere with other devices. The shield minimizes capacitively coupled noise from other electrical sources. The shield must be applied across cable splices.
In shielded signal cables the shield may act as the return path for the signal, or may act as screening only.
The KS is the variable-voltage signal source, not the ECU. So that signal doesn't need a return path to it's source. Hence there's no real need for a sensor ground(E2) wire to it(most of the time).
icentropy
09-16-2020 02:47 PM
smiley52
07-11-2015 05:16 AM
Huntingtruckcletus
07-08-2015 05:26 PM
bryan34w
07-06-2015 05:53 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: 94 Pickup Knock Sensor Pigtail Ground
