91 pickup 22re code 43
Old 05-08-2008, 08:39 PM
jwc1989's Avatar
I have a problem with my pickup. I pulled the codes by jumping the terminals and got code 43…
STARTER SIGNAL--NO "STA" SIGNAL TO ECU UNTIL ENGINE SPEED EXCEEDS 800RPM
--IGNITION SWITCH/CIRCUIT
--ECU
Now the only I have recognized symptom is a rough idle, which when the engine is cold is hard to detect because it sounds like it idles fine, but with concentration I can notice a slight hesitation. Once it warms up to normal temp ranges the idle hops around idling anywhere from 750-1400 (give or take 50rpms). To give you guys a better idea of what I mean it is running like the engine is overheating and trying to spin the fan faster to cool it down but maintain a normal idle, but it’s not overheating. After a few seconds of it doing that it idles fine; higher then normal, but at a steady idle around 1000-1250. I have felt some hesitation while driving only when I take my foot off the gas… My dad says it sounds like a vacuum problem and I just wanted to get your opinion before I go head first into this.
Old 07-05-2021, 03:19 PM
Santos77's Avatar
--ECU
Any solutions?
I live in California, and I have the same problem but I have to fix mine asap for smog check...
my codes are 43, 52, 71
1989 4runner (daily)
1990 22re
yotapwru
Washington
04-07-2016 01:41 PM
Junkers88
10-09-2009 06:26 PM
rfich53
05-12-2006 04:04 AM
ATA_Spiffy
03-29-2006 06:48 PM
Dorian
9
01-08-2003 06:47 PM
Quick Reply: 91 pickup 22re code 43
