'90 toyota pickup, cant shift when stopped
Old 03-30-2013, 05:12 PM
koda's yota's Avatar
i have a 1990 toyota pickup with a 5 speed and recently when the truck is stopped i cant shift into first (and sometimes any other gear) or its really tough, and if i try to put it into reverse it grinds, like the clutch isnt disengaging the tranny from the engine. if any one has any ideas as to why this is happening and/or how to fix it, id really appreciate it.
Old 03-30-2013, 05:28 PM
Co_94_PU's Avatar
Check your fluids (tranny and clutch), adjust the clutch pedal push rod(FSM), and start saving for a new clutch plate replacement.
clutch touble shooting check list
Old 03-30-2013, 06:48 PM
shaeff's Avatar
Either what he said ^ or you've got clutch pedal bracket failure, as seen here:
https://www.yotatech.com/forums/f116...fatigue-32667/
Old 03-31-2013, 04:52 AM
Edionne13's Avatar
I know this fully doesn't answer your question butch hen shifting in reverse I bekeive we always grind in. But to make it smoother shift from second gear to reverse. If that doesn't do it shift through every fear then reverse
Old 03-31-2013, 11:41 AM
Co_94_PU's Avatar
No it shouldn't grind in any gears. If it does it needs adjusted.
When the clutch seems ineffective, release the clutch pedal and then depress it again. This will work most of the time, it's covered in the manual(somewhere).
Old 03-31-2013, 12:06 PM
Edionne13's Avatar
Really?! What would need to be adjusted I have only a year old clutch. It still does it when I first got my pickup
Old 03-31-2013, 12:25 PM
Co_94_PU's Avatar
As above fluids and adjustments.
Old 03-31-2013, 05:19 PM
rbuchmann's Avatar
All good suggestions above. Take a flashlight and stick your head under the dash, and look at the bracket your pedal is attached to, in the upper left, and see if its cracked. If not, have someone depress your clutch pedal while you stick your head under the truck and see if your slave cylinder is moving properly. If those are all good, it could be a clutch master that's out. It's all easy to check. If it was working and now its not, its got to be one of those things.
Old 04-01-2013, 12:23 PM
benwahballs's Avatar
+1 on clutch bracket failure, symptoms are identical to mine when it cracked. Can be tough to see the crack, depress the pedal w your hand while watching the bracket and see if it has any give/play.
6th Gear
19
12-10-2019 07:31 AM
Weidle
01-21-2019 05:39 AM
Aleeex_u
06-05-2016 06:52 PM
GorgeRunner
06-27-2015 07:01 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
Quick Reply: '90 toyota pickup, cant shift when stopped
