90 4Runner Electrical issues
Old 07-25-2009, 04:43 PM
Helidoc's Avatar
My son has a V6 A/t 4wd 90 4runner. I have some intermittent warning light problems. The Brake, A/T fluid temp, and Battery light are on all the time. All 3 are either on or off. He has a new battery and Alt. Voltages are good on both. I haven't read anything on the A/T fluid temp. Brake light wiring seems to be ok. (fluid is good and continuity check of float is good) EBrake switch is good. But like I said it seems to be intermittent. I do not have a CEL, I did the jumper wire to chk the ECU and it threw no codes. With the turn signals on the 3 lights will flash (dim) and just barely noticeable. Like there is a bad ground some where. But all the grounds look good. we are in the process of chking them all. I have a set of service manuals but are vague when looking for this particular problem. Any help would be appreciated. Thanks Stu
Old 07-26-2009, 09:26 AM
Helidoc's Avatar
No Ideas?
Old 07-26-2009, 04:44 PM
iselloil's Avatar
Look at the harness above the rear axels,passenger side,There is a plastic sleeve,look for a broken wire. There is a broken ground in the harness.
Old 07-27-2009, 06:58 AM
Helidoc's Avatar
thanks, will do
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
coryc85
09-09-2015 06:24 AM
Yota.Jay
07-23-2015 08:08 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 90 4Runner Electrical issues
