'90 22RE p/u 2&3 cyl not firing
Old 11-28-2012, 07:13 AM
Cadin's Avatar
I found mine as well, ended up being a loose ground on the back of the head. Cleaned it up, tightened it up, runs like a top.
Good Luck!
Old 12-07-2012, 03:27 AM
dhickman's Avatar
Found a vacuum leak at base of carb, got to talk wife into a new Offy intake Sweet! Truck runs like it is supposed to
Old 03-18-2013, 10:59 AM
ogjohnboy's Avatar
update, had the injectors plug up again so i parked it due to going to arizona for about 4 months. Came back and planned on fully cleaning the fuel system.
So i pulled the intake, then injectors and sure enough, all the injectors were pretty plugged but shot them with a bunch of brake cleaner and they looked good as new. Did the same for the fuel rail, inlet hardline and cleaned the fuel filter out with some fresh gas due to it only having like 200 miles on it since the last time i pulled the injectors.
Pulled the bed, and removed the fuel pump assembly and EVERYTHING WAS RUSTED! Apparently the truck sat for a couple years with fuel in it when one of the previous owners had it. Also the suction screen on the fuel pump was basically non existent so i bought one of those. Drained all the red rusty fuel out, pressure washed the entire tank and dried it, got it all reassembled and fired it up, truck now runs like a champ!
So all in all this repair cost only $17.00 this time but i wish i would have just done this in the first place. Everything else i had already (brake cleaner and what not) Grand total over the year is around $400 for new injectors, fuel filter, CTS, thermostat.
Now I need to track down a W56 transmission so i can replace mine due to 1st, 3rd and 5th gear having a bearing noise, 3rd syncros and 4th syncros are almost non existent and it will pop out 1st when you let off the throttle.
But ill get to that some other time because i want to get started on my 87 toyota to get that back on the road.
Old 03-18-2013, 01:56 PM
Co_94_PU's Avatar
You don't mention repairing the lining. If you don't do this it'll just happen again.
http://www.oreillyauto.com/site/c/se...yword=red-kote should be about 30$ and gets rid of the issue.
Old 03-18-2013, 02:39 PM
  #25
ogjohnboy's Avatar
i thought about doing it but with the marine grade liner but due to being unemployed and on a very very tight budget it wasnt too large of a concern to me. later on down the road ill do it but until then i should be fine. would rather do it when its a bit warmer anyways.
Old 03-18-2013, 03:35 PM
  #26
Co_94_PU's Avatar
I hear ya! Trying to get two or three warm and dry days in the middle of winter or early spring. Not really easy
Should be a lot better off with the screen replaced, will definately buy you some time
Old 03-18-2013, 03:41 PM
  #27
ogjohnboy's Avatar
yeah it was pretty funny finding the screen so degraded, the mesh was almost completely degraded so it was motstly just the plastic frame. if i get a chance ill put some pictures up of the whole ordeal.
But who knows how much longer ill even keep this truck, ive never been a big fan of 3rd gens and would really rather trade it off for a second gen truck or maybe a 4runner.
Old 06-01-2014, 11:07 AM
  #28
broncotoyo's Avatar
so i keep hearing injectors weak fire in same sentence so does that mean my weak spark on 1 and 3 could be due to injector wiring
Old 06-01-2014, 05:33 PM
  #29
Cadin's Avatar
Same sentence? Your spark strength is unrelated to the injector wiring, you can "rent" a noid light tester kit from Oreillys/Autozone/Advanced Etc. to test the injectors firing.
Old 06-04-2014, 04:32 PM
  #30
broncotoyo's Avatar
to me my spark looked weak. first time dealing with fuel injected but i found my problem due to you guys and my truck was down 6 wks. had engine rebuilt and it was missing on 1-3 when i put it back in and finally i checked wiring and found on #1 injector it was like some one had pushed my wires back into the plug. had a theif hanging around for a couple days so. and no i didn,t know until i went to use my compressor and skil saw and they were gone.
Old 06-04-2014, 07:42 PM
  #31
Cadin's Avatar
Bummer about the compressor and saw, but good you found the problem!
Old 06-09-2014, 09:30 AM
  #32
broncotoyo's Avatar
thanks for every thing wouldn, t of figured out what was wrong with out the help here
MMA_Alex
25
04-18-2017 05:07 AM
Dennisx2
08-10-2015 06:48 AM
Dennisx2
08-04-2015 01:26 PM
boogiewoogie
07-24-2015 05:10 AM
Quick Reply: '90 22RE p/u 2&3 cyl not firing
