89 yota 22r Stalling at stop signs
Old 03-11-2010, 09:59 AM
cfhrduncan's Avatar
I just installed a new clutch kit and flywheel. now starts up and shift fine but when i stop at stop signs it stalls out. Instead of droping to idle it just drops out all together. any suggestions or ideas would be great.
Old 03-11-2010, 10:12 AM
broncrider's Avatar
did you make sure to bleed the clutch? flywheel new or resurface
Old 03-11-2010, 10:18 AM
cfhrduncan's Avatar
Flywheel was new, and I did bleed the clutch because I also replaced the slave cylinder.
Old 03-11-2010, 11:48 AM
broncrider's Avatar
something isnt right then. does it idle when you just sit there with the truck in netrual. does the truck chug as your stopping or does it just die.
Old 03-11-2010, 12:05 PM
Stroheckeral's Avatar
i dont know if it will help but i had the same problem on my 89 22re EFI it was the idle adjust screw. it would screw in by itself so i locktighted the thing and set it where i wanted befor it dried.
Old 03-11-2010, 12:09 PM
before fix i had to pull up to a stop with my feet on the clutch, break, and a little on the gas. It can get difficult adjusting the gass with you foot on the break at the same time.
Old 03-11-2010, 12:25 PM
xxxtreme22r's Avatar
maybe the clutch isn't fully disengaging, after my rebuild and new clutch install I had to re-adjust the nut under the clutch pedal to get mine to quite grinding gears, maybe your is worse in adjustment than mine was.
Old 03-11-2010, 01:37 PM
cfhrduncan's Avatar
that sounds like what i got going on. the is no problems shifting or going in and out of gear. hopefully I just can ajust the idle screw, maybe some thing got thrown out of whack when I pulled the tranny. bearing was seized really bad.
Old 03-11-2010, 01:41 PM
cfhrduncan's Avatar
It idles fine when first started, and it runs normally until I come to a stop. there is not any kind of chugging/glugging, it just dies out if i don't give it a little gas.
Old 03-11-2010, 02:06 PM
with my problem, the vibration of the engine would turn in the idle screw. I would adjust the scew and it would start fine and be ok for a little but eventualy the screw would always turn in
Old 03-11-2010, 02:11 PM
cfhrduncan's Avatar
Thanks I'm going to adjust it asap. I'll let you know what happens, thanks for the help.
Old 03-11-2010, 02:20 PM
Junkers88's Avatar
X2 on that one. I freaked out when mine did that the first time.
Old 03-21-2010, 04:30 AM
Well, did you fix it?
Old 03-24-2010, 03:04 PM
brotherstruck's Avatar
i have the same problem but i dont know which screw is the idle adjust screw, any one have a picture or something
Old 03-24-2010, 03:17 PM
Junkers88's Avatar
Old 03-24-2010, 03:28 PM
Originally Posted by Junkers88
Nice clean engine you got there
Old 03-24-2010, 03:56 PM
mines carbed but doing the same thing, anyonr have a picture of the idle screw on a carb?
Old 03-24-2010, 04:36 PM
Junkers88's Avatar
Oh. Sorry I was thinking 22re (injected).
Old 03-24-2010, 05:03 PM
cfhrduncan's Avatar
Thanks Stroheckeral that did it, sorry took so long to post results spring break and I post from the colleges computers.
Charecter1
11-06-2023 10:08 AM
sandyota
02-04-2021 11:16 AM
Sleaker
08-26-2020 06:03 AM
_Nicco_
08-28-2015 07:26 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 89 yota 22r Stalling at stop signs
