88 toyota pickup cab interior grounds.
Old 11-12-2011, 06:24 PM
sparkchaser's Avatar
Can anyone tell me where on a 88 22re toyota pickup are the right hand and left hand back panel? Also the right and left rear panels? Its a standard cab. I've researched the fsm and my haynes manual. They give me the ground points but I am unclear as where to find them? Any help?
Old 11-12-2011, 09:38 PM
wyoming9's Avatar
Wink
Look for the color wire that is shown in your manual with a ring terminal crimped on and screwed into the door post on the right and left side.
With a truck this old they could have been moved for any number of reasons
The left side one is easy to see
just what is not working??
Old 11-13-2011, 10:55 AM
Thanks for the info. Those grounds probably have been moved. I bought this 88 toyota pickup 22re in august. One day I go into town and after my second stop I attempt to start the truck and nothing works. No lights,no accessories,nothing at all. I thought about the battery first since it was pretty old and it would not jumpstart. I bought a new one and no results. The only signs of any voltage is the flasher relay in the drivers kickpanel chatters when you activate the hazards and a low hum when turning on the parking lights. I ohmmed out the starting circuit that applied to a manual transmission from my haynes manual. No wires seem to be broken. I removed and cleaned all the engine grounds for good measure. It seems to me it would be a ground since I lost so many things together. Any ideas?
6th Gear
19
12-10-2019 07:31 AM
Weidle
01-21-2019 05:39 AM
5280jo
10
07-13-2015 10:05 PM
paxanders
06-21-2015 06:29 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: 88 toyota pickup cab interior grounds.
