87' 4Runner radio wiring help.
Old 03-18-2010, 05:17 PM
Midyew59's Avatar
I am a new member and i'm in the process of cleaning up a mess of an installation that was made by another person when i had the stock radio replaced with a CD Player. The harness got cut and trashed, and everything was just spliced by being twisted and electrical taped. The ground came undone about a year ago and took my blinkers with it, but i got them back now. I went and put female disconnects on the wires in the dash and the male disconnects on the radio wires so i all i need to do its attach them (should work and be safer than what was there)
Now that i have it all cleaned up and ready to be connected to the the new CD Player I need to know which wires go to what...i have no clue.
I have a pictures with labels that hopefully will help. If anything, how can i figure out what each one is on my own?
Thanks much
Old 03-18-2010, 05:28 PM
yotaman85's Avatar
someone else will say it so i might as well, if you have a repair manual check that. what year and model is your toyota?
Old 03-18-2010, 05:33 PM
Midyew59's Avatar
I have a Haynes manual but I can't seem to find anything about the radio wiring anywhere, but if its there then I'm missing it and need to look harder.
and it's a 1987 4Runner.
Old 03-18-2010, 05:34 PM
yotaman85's Avatar
hope this helps.
Right Front Speaker (+) Green Gray
Left Front Speaker (+) Pink White
Right Front Speaker (-) Blue Gray w/ Black Stripe
Left Front Speaker (-) Purple White w/ Black Stripe
Ground Wire Black Black
+12 Volt Ignition Wire Gray Red
Power Antenna Wire Blue (join wires 1 & 2 Power Antenna Wire together)
Right Rear Speaker (+) Red Purple
Right Rear Speaker (-) White Purple w/ Black Stripe
+12 Volt Battery Wire Blue w/ Yellow Stripe Yellow
Left Rear Speaker (+) Black Green
Left Rear Speaker (-) Yellow Green w/ Black Stripe
Old 03-18-2010, 06:02 PM
Midyew59's Avatar
Thanks for the info, but it doesn't really help. I was looking in the manual and i found that (apparently) the red/black wire and the green wire (not light green) go to the radio and the others are for speakers, ect.
So out of the red/black/ and green wire, one must be the power and the other one is something else, not related to speakers.
Old 03-18-2010, 06:06 PM
Midyew59's Avatar
And after looking at this....
1987 Toyota 4Runner Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow or Blue/Black
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Out of the two wires mentioned in the Manual, the green one must the the illumination and the red/black the power. and i guess the brown wire is the ground....so that leaves the speaker wires to figure out then right?
:edit: The blue/yellow might be the power too so i need to find out which is which out of the two. How do i tell?
Old 03-18-2010, 06:26 PM
Midyew59's Avatar
OK, i think i got most of the wires figured out, the only thing left to do is figure out which wire is the main power, the red/black wire or the blue/yellow wire. And what the one that isn't the power, what it does.
Old 03-19-2010, 04:00 AM
milehigheric's Avatar
Get a multimeter and learn how to use it....I don't see why anyone attempts any wiring projects without one.
Old 03-19-2010, 04:38 AM
67ghiaTIV's Avatar
I just did this 2 days ago.
Here you go,
Wiring info, look at the 87 and newer.
http://i51.photobucket.com/albums/f3...ta-wiring1.gif
I only used pin A-G, I believe our power antenna is a red/green stripe wire
I double checked all the info in this chart with a meter and it all worked. You can use a small 12V test light to double check the power wires.
Jamie
Old 03-19-2010, 07:19 PM
LITLRED's Avatar
Check this out! http://www.the12volt.com/installbay/...TID~74637~PN~1
Old 03-28-2018, 01:15 PM
Michael Folia's Avatar
Thanks much
Im having the same problem of putting in an aftermarket stereo. I like what you’ve done, but did u just cut the wires out of the oem plugs
Old 03-28-2018, 01:30 PM
akwheeler's Avatar
This is an 8 year old thread, it isn't likely that you'll get a response form the original poster (OP). Do yourself a favor and don't cut the vehicle wiring harness to install an aftermarket stereo, just spend a few bucks and get the installation harness that plugs into the vehicle harness. Then you can make all of your splices on a workbench and plug it in. Also don't use crimp type butt connectors, do it right with solder and heat shrink.
Old 03-28-2018, 02:00 PM
RAD4Runner's Avatar
Agree 110% with AKWheeler.
In case this would help... found online...
TRUST IT BUT VERIFY. PHYSICALLY TRACE WIRES
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
MMA_Alex
25
04-18-2017 05:07 AM
toyota32
07-06-2015 05:42 PM
colinmil
07-06-2015 04:03 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 87' 4Runner radio wiring help.
