87 2WD A43D OverDrive Solenoid Location
Old 08-09-2006, 12:05 PM
87beat's Avatar
Question 87 2WD A43D OverDrive Solenoid Location
dug through the links on here, found the link to the FSM for 93s
also found information on testing the relay. There's no pin in the relay for the temp sensor but other than that it tested fine, leading me to beleive that the OD solenoid needs replacing.
Finally arrived yesterday, itching to see if this is actually the problem. never done this before so I was looking for advice, any tidbits of info that I might need to not screw this up, etc. (and the location of it - I think it's on the side of the tranny drivers side)
I don't know a thing about working on trannies, though I learned that the solenoids generally work together to choose the gear you're in. from what I've read, there's only the OD solenoid on this tranny and instalation looks simple enough - 2 bolts and a single plug, but I'd rather be extra sure.
INFORM ME!
Old 08-09-2006, 05:53 PM
87beat's Avatar
well I crawled around under there for awhile and found the solenoid, drivers side. I'll dig her out first thing in the morning and see what happens
let me know if anyone wants pics of it
R
Old 04-28-2024, 07:16 AM
sourdough's Avatar
Haha, old thread. there is a fix, AW71A43D O.D. Solenoid bypass kit for Toyota. Search eBay sales listing and read description.
87-4runner
08-24-2022 09:29 AM
chuckross1957
06-28-2019 10:19 PM
93runnerguy
11-30-2010 03:56 PM
MisterB
09-20-2009 09:47 AM
elnido
04-30-2005 11:33 AM
Quick Reply: 87 2WD A43D OverDrive Solenoid Location
