87 22RE engine wiring harness help!!
Old 08-28-2009, 02:48 PM
mannequin939's Avatar
I am currently putting back together my engine that i just rebuilt and there is one wire connector from the wiring harness that i cannot figure out where it plugs into. any help would be greatly appreciated
Old 08-28-2009, 02:57 PM
RMA
RMA's Avatar
looks like it would go to the cold start injector , maybe ..
Old 08-28-2009, 03:03 PM
LD
LD's Avatar
either air valve under intake manifold, fpr vsv on the valve cover, or coolant sensor below the throttle body. all are green on mine.
Old 08-28-2009, 03:07 PM
theres no way it would reach to the throttle body or up to the valve cover... plus i have every other electrical plug accounted for on the harness...i'll check again under the intake manifold
Old 08-28-2009, 03:10 PM
it was under the intake manifold.. cant believe i missed that... thanks everyone for your help
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Regency
20
01-03-2020 07:43 PM
God's Bounty Hunter
07-08-2015 12:54 PM
toyota32
07-06-2015 05:42 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: 87 22RE engine wiring harness help!!
