87 22r 5spd Pickup Loud Hissing Under Acceleration
Just noticed the sound yesterday, and even more so today with my windows down.
With the engine warm, under moderate to heavy acceleration there is a loud constant hiss coming from, as far as I can tell, underneath the truck cab.
I thought that maybe this was my clutch starting to slip but i can hear no noticeable increase in RPM.
I also am fighting a ping but i am not sure if that is related to this problem.
Any help would be appreciated.
I had similar and it was an exhaust leak at the manifold to down pipe flange joint. Sounded like a vacuum cleaner or a Chevy V-8 swoosh noise. One bolt had worked very lose and an other a little loose. There was a small separation. Tightened all three and the noise went away.
Make sure your air cleaner lid is on properly. If a snap closure is loose, or the wingnut in the middle is loose, it will hiss like a rattlesnake whose tail got stepped on.
I know, it's happened to me a couple times now, especially if I get in a hurry closing it up after working on it.
Let us know what you find
Pat☺
Pat☺
The following users liked this post:
JoeS (09-17-2022)
ilovelivinginthecity
10-25-2012 08:50 AM
