Which 60mm TB for my 22re wil plug and play?
Old 02-19-2010, 04:43 PM
dfarr67's Avatar
AZ where did you get the overbore done? $$? new butterfly too? Worth it?
Old 02-20-2010, 11:09 AM
AzStorm's Avatar
I went with the LCE Throttle body (4mm overbore) and had a local machine shop bore the intake.Cant remember the name,it was 5 years ago.You will have to readjust the TPS after the install of the bolt on TB from LCE.
I believe the stock bore was 55mm
Combined with the other modifications I made(head,cam,valves header,exhaust etc.) I am quite pleased with the performance over stock.
Old 02-20-2010, 02:40 PM
dfarr67's Avatar
Sorry misunderstood- that's done already in my case- LCE is the only ones in the game...
Old 02-27-2010, 02:26 PM
cincy85runner's Avatar
I have the EFI performance kit for my 85 4runner which has the throttle body spacer would I have to have the intake bored to match to get the true potential out of the upgrade? and would this afm upgrade make any difference?
Old 02-27-2010, 02:28 PM
  #25
BigBluePile's Avatar
It wouldn't hurt.
Old 02-27-2010, 03:29 PM
  #26
JamesD's Avatar
What I would do is take the stock 22RE TB apart and get it bored 5mm over. Then take the 5MGE throttle plate itself and bolt it in the bored 22RE TB then it will be a direct bolt on. Another thing, I have yet to see any dyno number from any engine mods that are done on our Toyota engines like the 22R or the 3VZ. The butt dyno is not that accurate and it may be a waste of money for the gains that you do get. Not saying not to try any of this stuff but before you go off spending hundreds of dollars, you might want to find out if it is actually worth it. The best mod I think is a regear. Made a world of difference on my Toyota trucks.
James
Old 02-28-2010, 08:57 AM
  #27
dfarr67's Avatar
Check out 'polarbeartuning' he has expressed some interest in boring out the TB's- he already does Honda and Acura, I think he will come in around $150. Email and show him some interest. Talking to a guy about the MAF conversion- we'll see where that goes. Supra TB conversion- dead. Supra AFM, in and running- was it worth it- I don't know yet.
Old 03-01-2010, 05:06 PM
  #28
dfarr67's Avatar
check out;
Maxbore.com
Full Throttle Speed.com
Old 03-01-2010, 06:44 PM
  #29
dfarr67's Avatar
This is from MaxBore- I'm going to call him tomorrow. And forget about the converter- same idea as I wanted but won't work for my application- I've emailed the company, but still pretty sure the ecm won't understand that unit. BTW anybody here have a good 1990 TB they want to sell? I need a core. Or if a few of us are interested- perhaps we can pass a loaner TB around? I've got a 1992- looks the same but can't get it to run- idle issues even with a rest TPS.
Hello Dave.
I don't get those Tbs to bore so I don't know exactly how much bigger I can make them. On average, I can bore TBs 3 to 4mm over.
I don't provide cores since I would assume responsibility for it fitting and working in your vehicle. I would recommend that you send in a spare TB that you know works with your engine, that way you have no down time and can revert to stock if you need to.
You may reach me at 321 277 6151.
Thanks
George
Old 03-01-2010, 07:55 PM
  #30
Nashman00's Avatar
i just used 7mgte one works great all the bolt holes line up too, just have to hog out the stock manifold
the stock tps bolt on as well
can't ask for any thing better then that i used a 89 plus thottlebody but there allt he same pretty much
Old 03-02-2010, 08:05 AM
  #31
dfarr67's Avatar
Well- his price is $125 shipped, 60mm vs 59mm- and the headaches of fitting it. I just sent a 5mge back. I don't have access to a good Toy scrap yard.
Old 05-29-2010, 09:01 AM
  #32
dfarr67's Avatar
Maxbore= great product, just be sure you set up everything as far as specs go.
Old 09-24-2013, 11:42 PM
  #33
-City Slicker's Avatar
hey
I was at the junk yard all day
I have 3 TB's hidden
2 7mgte
1 5mge
can you please send me a photo of the one that you are using..?
Doug4320
03-24-2018 10:11 PM
crashburnoveride
08-28-2015 09:20 PM
kcaudill
07-20-2015 12:06 PM
msane99
07-17-2015 10:13 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Which 60mm TB for my 22re wil plug and play?
