YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-24-2008, 07:11 PM   #1 (permalink)
fireman1559's Avatar
4x4 not working
i just bought my second toyota sr5 pickup i had a ford it was crap from day one but anyways i just got the truck and the guy i bought it from said that the front 4wheel drive was not working and i know you have to lock the front yourslef but that still doesnt do anything any help wold be great
thanks mike
fireman1559 is offline
Sponsored Links
To remove this ad, register today!
Old 07-24-2008, 07:24 PM   #2 (permalink)
Does the front driveshaft turn when you put the transfer case in 4hi or 4lo? If not, you need to troubleshoot the transfer. If it does, then, you need to start with the hubs and work your way in to the third member.
__________________
94 X-cab, SAS, LT1, T350, 205TC, 33" swampers, molded bushwackers
94 Springer Softail, 7 gal stretched tanks, 16" ape hangers, kick/electric start, dakota digital dash
one2high is offline
Old 07-24-2008, 07:30 PM   #3 (permalink)
TOYOTA 1's Avatar
x2.......
__________________
91 toyota stdrd cab short bed 22re 5spd. sas'ed hy steer. 3.5" tuff country e-z ride springs in the front. 5" allpro longtravels in the rear. es 9000's, 12" tg long spline front d shaft. k&n 35x10.50x15 boggers. cobra cb/ashtray mod, 3' firestick. etc.
2000 toyota tacoma xtra cab sr5, 3"revtek,285/70/17 coopers stt, clear tails, injen short ram intake, obx header, flowmaster, etc.
2001 toyota camry, the girlfriends,
Sierra Club sucks!
TOYOTA 1 is offline
Old 07-24-2008, 08:15 PM   #4 (permalink)
yes the driveshaft turns when it is in 4hi and 4lo
__________________
FIRST-truck 1990 SR5 pickup 4x4 cracked head ran for a year had over 360,000miles with the 3.0L v6
SECOND-truck 1997 ford f150 with the 4.2L v6 bearly 100,000 miles when it runs i got 8mpg WHEN it ran
THIRD-truck 1990 SR5 pickup 4x4 3.0L v6 150,000 miles runs like i bought it in 1990
life lesson ford sucks toyotas rock!!
Old 07-24-2008, 08:26 PM   #5 (permalink)
RobD's Avatar
Does it have locking hubs on the front, such as Warn or Aisin, or does it have the ADD system?
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio
RobD is online now
Old 07-24-2008, 09:11 PM   #6 (permalink)
its all stock so i have no clue
__________________
Old 07-24-2008, 09:13 PM   #7 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
Or does it have both? To check for ADD, look at the front differential, there should be an actuator on the drivers side stub shaft, and some vacuum hoses comming out and going into the engine bay.
What kind of hubs do you have? Go and look on the hub dial, it should say...
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 220,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace| Marlin armor | Amsoil synthetic drivetrain fluids
http://www.cardomain.com/ride/2572486
Jay351 is online now
Old 07-24-2008, 10:03 PM   #8 (permalink)
im gonna say it has the ADD my first yota did its to dark to tell but i think it does
__________________
Old 07-24-2008, 10:08 PM   #9 (permalink)
Jay351's Avatar
Check it out tomorrow. If it does, there might be a problem with the actuator or vacuum hoses.
Does the 4wd light come on? Do you here a click when placed into 4wd?
Does it do anything different then your other rig?
__________________
Old 07-24-2008, 10:12 PM   #10 (permalink)
the light comes on and i hear a click
__________________
Old 07-24-2008, 10:16 PM   #11 (permalink)
904_runner's Avatar
If the light comes on i thought that meant the front shift tube is in the locked position. How does this guy know the 4wd doesn't work? If i were you i would jack up the front end and turn the truck on and put in 4wd, then turn one of the front wheels and see if the other one turns, this should also turn the driveshaft if it working
__________________
-Mike
1990 4runner SR5, 3.0 with 250K, 5-speed, 4.56 gears, warn premium hubs, Hella 500's, Rancho 9000's, 33X12.50's crappy dunlop tires, rear lock right, 4" trailmaster lift with lc coils in rear, panhard drop bracket
Soon to come: New wheels and tires, Sliders, CB.
One Day: 3.4 swap!
www.myspace.com/222948743
904_runner is online now
Old 07-24-2008, 10:19 PM   #12 (permalink)
i had it on a lift in a shop checking things out before i bought it thats when the guy told me the front 4wheel drive doesnt work
__________________
Old 07-24-2008, 10:28 PM   #13 (permalink)
904_runner's Avatar
okay, well when i first got mine it didnt work either, i ended up throwing on some manual hubs, and messing with the vacuum lines in order to bypass the vsv switches for the A.D.D and locks the shift fork in place.
sorry, i cant post the link for some reason, search for it
"many many questions" Only a few days ago
well there are some pictures, you can only do this if you put manual hubs on. I would try diagnosing your problem unless you want to switch from A.D.D to manual
__________________
-Mike
One Day: 3.4 swap!
Old 07-25-2008, 04:57 AM   #14 (permalink)
TomThumb's Avatar
If you hear a "Click" should be from behind the dash, that means that the shift lever is engaging the ball switch in the trans case and activating the ADD relay. Which will in turn activate the VSS switches under the hood on the pass side. The light coming on the dash should only happen when the locking sleeve has moved over on the front axle putting the truck in 4x4, To me that would show that the add system is working correctly. If you can turn the front drive shaft with the truck in 4x4 and still on the ground my guess is you have issues with the Tcase internals.
Here is a great write up on the different systems used by Toyota found on the Offroad.com fourm. Also explains how to trouble shoot the add system. Found very helpful when geting mine fixed. Turned out to be a broken wire going from the tcase switch to the add relay behind the dash. Good luck!
http://www.off-road.com/trucks4x4/ar....jsp?id=399612
__________________
Quote:
Originally Posted by thook View Post
Ooooo....don't say that. Next thing you know somebody's truck'll blow up following my advice....:nerd:
It takes hundreds of nuts to hold a car together, but it takes only one of them to scatter it all over the highway.
- Evan Esar American Humorist (1899 - 1995).
1991 Toyota Pickup EXT> RIP... ROD Knock/Rustie's.
1992 Eagle Talon 5Speed> Sold...
1993 Toyota Pickup EXT 22RE 5speed> Current Beast
TomThumb is offline
Old 07-25-2008, 05:53 AM   #15 (permalink)
thanks for yalls help i guess its time to see what i can do to get it fixed
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Toyota's for Parts or Complete 85 Truck 4x4, 88 4 Runner, 1993 Truck 4x4, 81 P/U 4x4 jbm715 Vehicles - Trailers (Complete) 23 04-13-2008 05:45 PM
for sale:2002 chevy duramax 2500 4x4 crew cab 4x4 NG Crawler Vehicles - Trailers (Complete) 10 01-27-2008 10:08 PM
4x4 isnt working premirrider 86-95 Trucks & 4Runners 19 11-24-2007 02:24 PM
86 4x4 turbo -at TURBO WORKING? Bociba 86-95 Trucks & 4Runners 10 11-23-2007 05:34 PM
4x4 working intermittantly wholiman 86-95 Trucks & 4Runners 5 01-23-2006 06:57 AM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.1.0
2002-2008 Yotatech.com
