3VZE Spark Plugs, Which one do you use?
Old 09-13-2010, 12:03 PM
Ninja 85's Avatar
I have found the best so far are the E3 plugs. Noticable difference in power and milege. For the 3VZE engine part #E3.48
Old 09-13-2010, 02:39 PM
aa1911's Avatar
NGK V-power for me, came pregapped to 0.44, they were right on the money when I checked them and they run excellent
Old 09-13-2010, 04:55 PM
MudHippy's Avatar
Say what? In your 3VZ-E? Who gave you/where did you get those? Someone screwed up there, that's for SURE!
NGK V-power, or any spark plugs for the 3VZ-E, are supposed to be pre-gapped to the factory specs of .032".
There's no way that your running any engine on plugs gapped at 0.44. You do realise that's almost 1/2 an inch of gap right? What did you measure that with? Even if you meant .044" you must have some serious ignition upgrades. I cannot believe that you can get away with that on a 3VZ-E with a stock ignition coil and stock-type spark plug wires. So what gives?
Old 09-13-2010, 04:58 PM
JDS1992's Avatar
NGK G Power. What I used have 1600 miles on them so far no problems, Also I replaced my wires around the same time within 50 miles of the plugs..Getting good spark and power with good economy.
-Wires are also NGKs
Old 09-14-2010, 02:37 AM
  #25
TNRabbit's Avatar
I have 32,000 miles on a rebuilt 3vze with the Denso Iridium plug IK16 (5303) with nary a hiccup. Rock solid from idle up to redline; NEVER misses.
Old 10-05-2010, 12:52 PM
  #26
aa1911's Avatar
yeah, sorry about the gap, it's 0.032 for the 3vze, I posted this on another thread too, oops.... I was thinking of the wifey's honda, put NGK's in that thing too, they were .044's
Old 10-17-2010, 11:01 AM
  #27
954toy's Avatar
Exclamation ngk iridium's
so i installed a complete set of ngk iridiums after head gasket job. running like garbage. going to put in old plugs and recheck. it is acting like there is no signal. maybe hitting on 2 cyl. checked all usual suspects. even replaced cap rotor and wires. gapped to spec and proper install. killing me. any suggestions? after i replace old plugs i will repost results. please help!!!
Old 10-17-2010, 11:40 AM
  #28
808-3VZE's Avatar
Ngk V-power part# 2087
Old 10-17-2010, 12:29 PM
  #29
hgill's Avatar
Been using NGK V-Power .. work great!
Old 04-12-2011, 10:01 AM
  #30
ByThaBay's Avatar
I am about to put in a set of Denso Iridium long life plugs.. will update in a few years from now.
Old 04-13-2011, 06:59 PM
  #31
92 flatbed's Avatar
I put in the standard NGK's with fresh NGK wires...... works great
Old 06-18-2011, 11:52 PM
  #32
saladbarkido's Avatar
I'm using NGK G power. Although after reading this thread I think I might switch to V power so I can adjust the gap by about ~.02". Can't do that with the platinum's cause it will bend the tip.
Old 06-19-2011, 06:59 PM
  #33
Guardian_Saint's Avatar
I am having problem with them ngk v power but they work great though. The problem is from the piece were u gap between the fork. It chip off often time so I change them to the a utolite double platium. Thinking of changing to E3 plugs.
Old 07-12-2011, 07:30 AM
  #34
coupstar's Avatar
Been up to my elbows all morning pulling sparkplugs out of my recently acquired '95 with a 3VZ-E since I have noticed some hesitation and a serious bucking at 50 MPH (its like somebody's under the car kicking it, but only at 50) Plugs are pretty covered in white stuff (ash?) and the electrode is pretty worn. (they were gapped around .040) getting new wires today as well. Hoping to see some serious improvement in power, mpgs and acceleration. Thanks for the thread- I've been wondering what I could do
Old 03-07-2012, 07:45 PM
  #35
ziplex's Avatar
Hello 2012! What gap is everyone running? Anyone like a non factory spec gap better?
Old 03-07-2012, 09:16 PM
  #36
Ninja 85's Avatar
Just a heads up those E3 plugs I used only worked for for 8 months..Defently not worth the $$$..I went back to Platnum Autolites..Best plug I have ever used for many many years on all my vehicles..Very forgiving and wont fail
Old 03-08-2012, 03:37 AM
  #37
TNRabbit's Avatar
I have 52,000 miles on a set of Denso Iridiums now. Nary a hiccup.....
Old 03-13-2012, 05:42 PM
  #38
1989FourRunnin's Avatar
So the standard call for a 3vze in a 89 4runner SR5 is .032 using NGK plugs and wires?
Old 03-13-2012, 09:17 PM
  #39
regnar11b's Avatar
My buddies in the 4 wheel assoc have always said anything with aluminum heads.. NGK all the way... 12yrs always used NGK and never had any issues.
Old 03-14-2012, 05:19 AM
  #40
Cool. What about the correct gap though? Is it .032 ?
Quick Reply: 3VZE Spark Plugs, Which one do you use?
