3vze hot start, ect?
Old 05-05-2018, 12:45 PM
joel1952's Avatar
Originally Posted by hillsteepler
Hey Joel, sorry, don't know how I missed your question for 3+ years. Or if you even care any more. But the ground wire did seem to be the long-term issue, hasn't happened again since.
Thanks for the update. Glad to know that worked for you!
Old 05-05-2018, 01:30 PM
hillsteepler's Avatar
You're welcome, glad I could add some useful info
Old 01-14-2019, 03:06 PM
bensyota's Avatar
Where is this ground wire located? Thank you
Old 01-14-2019, 04:15 PM
joel1952's Avatar
"... ground wire on the passenger side cylinder head. "
Old 01-15-2019, 06:48 AM
  #25
Yep, passenger side cylinder head toward the firewall. You can't really see it, I had to find it by feel then tighten it with a swivel and an extension on the socket.
Old 02-20-2019, 08:47 AM
  #26
DH4runner's Avatar
was plagued with hot starting for over a year as well and delt with it stalling at idle red lights and stop signs, wouldnt start for over an hour after cooling.. i replaced all my vac hoses because of a vac leek, didnt fix the hot start but helped it run better. Replaced cap/rotor, serviced the entire intake plenum suroudnings, gaskets, hoses, cold start injector, serviced the injectors, new spark plugs/wires, all helps but still no fox on hot start. Later found out i had a double missfire, dead injector #1 and a bad distributor, replaced them both and no longer unable to hot start!! runs great. Not sure if it was either or that fixed the issue.
94 3.0 3vze 2wd
Old 02-20-2019, 07:26 PM
  #27
Yikes! Sounds quite a bit worse than mine was...
Old 06-09-2019, 05:59 PM
  #28
bensyota's Avatar
Where is this wire located exactly. Thank you
Old 06-09-2019, 06:18 PM
  #29
It's on the passenger side cylinder head, near the back (firewall end), kind of tucked up under the intake manifold/structure. Can't remember if it ties into the wiring harness, or goes straight to the firewall... Sorry I can't be a little more specific or get a picture, I no longer own this particular 4runner.
bigjstang
08-25-2021 12:41 AM
smiley52
07-11-2015 05:16 AM
Avenged
07-09-2015 07:55 AM
MTLroadierunner
07-06-2015 12:17 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 3vze hot start, ect?
