3VZE Head Gasket Orientation
Old 06-30-2020, 01:41 PM
Akira's Avatar
Afternoon everyone! Started putting the 3VZE back together and as soon as I finished torquing down the heads had a second thought about the gasket orientation. They are both labeled "L" and "R" and i know they are on the correct sides. The "slipper plate" material is on the block deck. I have checked other posts for this but haven't come up with much, feel free to link me if you know where this info is.
Image of the gaskets (enginetech from Rock) below
I just want to confirm that the holes/openings indicated in the image above and corresponding identification below are correct. Seems like these would be oil passages right? I can't image coolant flowing to this side of the heads.... thanks for the help!
Old 07-02-2020, 12:11 PM
Grabbit89's Avatar
Correct, those are oil return/drain passages.
barthmonster
09-10-2011 04:05 PM
GorgeRunner
10-27-2008 11:32 AM
zlathim
08-11-2008 07:19 AM
printing
12-30-2006 12:12 PM
Quick Reply: 3VZE Head Gasket Orientation
