3VZE Erradic idle and jumping tachometer
Old 04-26-2012, 10:02 PM
adamthedroog's Avatar
So my truck does the thing where when you start it up again (after stopping at the store for example) it idles at 500 or so RPM. It seems like when I go to start it it just barely starts itself. Once I start going it gets itself back up to a higher idle. Problem then is that the idle jumps around from 750 to about 1100. Another thing is that when I let out the clutch the tachometer falls to about 500 or so RPM then jumps up to wherever it's deciding to idle. ALSO I notice that sometimes especially when revving high the tachometer jumps around a bit. It isn't throwing codes and it's pretty decently maintained. The only things I have left is a new timing belt and PCV valve. I'm at a loss.
Old 04-27-2012, 06:26 AM
Team420's Avatar
Could be any number of things really.... I would 1st start by cleaning the grounds to coil and igniter, jumping tach needle is usually associated with that, and could contribute to the jumping idle, then move on to testing your vafm, tps, and start searching for vacuum leaks.
Blamalam
03-12-2022 07:34 AM
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
mtc1105
08-04-2015 08:06 PM
Sidherish
08-02-2015 01:42 PM
91yotapup
07-27-2015 07:19 AM
Quick Reply: 3VZE Erradic idle and jumping tachometer
