3VZE ECU Pinout
Old 06-21-2006, 09:04 PM
Crymson's Avatar
3VZE ECU Pinout
Anyone have an electronic copy of one of these handy?
Old 06-22-2006, 02:30 AM
TNRabbit's Avatar
go to this link for copy of 1993 FSM: http://personal.utulsa.edu/~nathan-b...fsm/index.html
Are you talking actual ECU pinout or the connection under the hood?
Old 06-22-2006, 02:33 AM
TNRabbit's Avatar
If it's the ECU pinout, you'll find it at this sub-heading: http://personal.utulsa.edu/~nathan-b.../6combinat.pdf
Old 06-22-2006, 06:12 AM
snap-on's Avatar
http://www.snjschmidt.com/wiring/Eng...rol_3vze_1.jpg
http://www.snjschmidt.com/wiring/Eng...rol_3vze_2.jpg
http://www.snjschmidt.com/wiring/Eng...rol_3vze_3.jpg
http://www.snjschmidt.com/wiring/how_to_use_1.jpg
http://www.snjschmidt.com/wiring/how_to_use_2.jpg
The following users liked this post:
Leonel626 (04-25-2023)
Old 06-22-2006, 09:28 PM
Crymson's Avatar
Excellent diagrams snap-on, greatly appreciated.
Old 07-18-2010, 10:48 AM
xxxtreme22r's Avatar
edit: ooops, wrong thread. haha, please delete me.
Old 08-19-2020, 01:21 PM
BSA Auto's Avatar
Looking for a pinout
Long story short, i have a 94 t100 m/t with the 3.0 3vze. It has a no start condition. After I reset the ecu by taking off the battery cable it will fire one time. It seems like it wants to start but continued cranking reveals it has no spark. UNTIL i take the cables off and reset ecm all over again. Then, same thing, hits once and doesn't spark after. I've completed every check/test i have found so far with the coil being the only thing i replaced due to out of spec readings. Got a new igniter and tried that, didn't help. Same problem. Vaf checks good. Even opened it up carefully and inspected it. All good. I was told it ran perfectly and then the fuel pump went out and was replaced. It ran fine after that. Then wouldn't start one day. Based on what I've read this is the place to help me figure out what im missing.
Sumoco (09-22-2023)
Old 09-22-2023, 11:11 AM
Sumoco's Avatar
Were you ever able to figure this out? I'm having almost an identical issue myself
Kamaloha
10-16-2015 05:13 PM
alexcarey
10-14-2015 06:05 PM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
bradahman
10-01-2015 09:24 AM
Matthew Perez
09-28-2015 05:43 PM
Quick Reply: 3VZE ECU Pinout
