3vz coolant bypass pipe
Old 05-26-2012, 11:27 PM
954x4runner's Avatar
Im almost done with my headgaskets. The coolant pipe that runs in the valley, under the intake manifold. Is there supposed to be a gasket where the pipe meets the block? I can't seem to find one on the online parts websites. Its weird cause when I removed it, it doesn't look like there ever was a gasket. Seems like there must be something cause if it leaks you would have to remove everything to get to it. Is it safe just to use rtv??
Old 05-27-2012, 05:14 AM
rworegon's Avatar
There is no gasket there. The FSM calls for a bead of seal packing material (FIPG). I have used Ultra Black RTV (or similar) with no issues.
See page EG2-127, step 16:
http://www.ncttora.com/fsm/1990-1995...neme/cylin.pdf
Old 05-27-2012, 08:55 AM
Awesome thanks sir.
Old 01-24-2021, 04:07 PM
4runner4days's Avatar
@rworegon I'm a the same step of the HG replacement process. What about Permatex Ultra Grey or VersaChem Mega Blue? Do you think either of those would be fine for the bypass pipe gasket?
MasterOfNone
12-08-2019 05:40 AM
93fourunnerSR5
03-31-2019 06:58 AM
87roctruk
12-05-2015 06:21 PM
DupermanDave
10-22-2008 10:05 PM
rah1420
05-24-2005 06:02 AM
Quick Reply: 3vz coolant bypass pipe
