3.4 swaps galore. pics of 3 swapped trucks and more.
Old 11-17-2004, 08:50 PM
  #61
TSP-MIKE's Avatar
Originally Posted by 914runner
TSP - what did you do about the oil pressure gauge?
I swapped in the 3.4L sender and a new gauge and it still doesnt work
Thanks
What gauge are you using? The stock one from a 2nd gen?
Mike
Old 11-24-2004, 03:35 PM
  #62
TeamShiftPoint's Avatar
914runner...any luck with your stuff?
you should be using the 3.0 sender for the oil gauge.
Old 11-24-2004, 09:54 PM
  #63
muskie's Avatar
TSP- any issues with the 95 3.4? I have gotten a complete front half cut with only 40 000 miles on it. I had heard they had head gasket problems also, so I wanted to change them out before installing if needed. Luckily the truck comes with everything in the engine bay needed for the swap icluding the hard to find harnesses.
Old 11-26-2004, 11:29 AM
  #64
Scarbro22's Avatar
Has anyone in swapping in the 3.4L also converted their truck from auto to manual? Looking at the price difference in the conversion kits and always having wanted a manual, it seems like that might cut cost down. Any thoughts? Also is there any other conversion kit besides ORS's? Thanks
Old 12-02-2004, 11:04 AM
  #65
if you have 4wd, you can swap to manual but you can use the 3.0 manual tranny so that the Tcase will bolt up with no problems.
if you have 2wd, you can either swap to the 3.4 auto or the 3.4 manual tranny.
BTW, if any houston area ppl want to see the 3 swapped trucks, we're headed to the meet over at Tejas Toyota with Tundra Solutions on Dec 11th
http://www.tundrasolutions.com/forum...ad.php?t=32858
Old 12-02-2004, 01:52 PM
  #66
914runner's Avatar
Nope, no luck yet. I havent had time to work on it lately. I did however swap in the 3.0L sender and a new gauge about a month ago and I think when I started it up it fried the new gauge! Any idears?
Thanks
Old 12-02-2004, 08:14 PM
  #67
TSP-MIKE's Avatar
Thanks
Sounds like a wiring problem. If it fried the gauge then someone hooked up the wrong wire, prolly giving the oil gauge directly 12v or something.
Mike
Old 12-02-2004, 08:29 PM
  #68
914runner's Avatar
Ya, Im going to go through the oil pressure sender wiring when I wire up my tach. How is the oil pressure sender sussposed to be wiried up? Directly from the sender to the gauge?
Thanks
Old 12-04-2004, 05:07 PM
  #69
TSP-MIKE's Avatar
Thanks
Yes you will need to directly wire up the oil pressure sending unit to the gauge. Lemme know if it works;
Mike
Old 04-25-2005, 07:01 PM
  #70
photomike72's Avatar
Holy Cow. What would you charge if I had a sourced engine? I'm currently getting another rebuild put in right now, but depending on your price I may start stocking up on parts to have this done.
Thanks!!
Mike
Old 04-25-2005, 07:10 PM
  #71
KevyWevy's Avatar
he might not reply. this is a pretty old thread. try emailing the guy
Old 04-25-2005, 07:15 PM
  #72
jc1kz's Avatar
Originally Posted by 96LtdYota
the grille on the white 3rd gen is sweet... how is that done?
that's a stock grill for the 2001 runners
Old 04-25-2005, 07:21 PM
  #73
word.
Thanks!!
Mike
Old 04-26-2005, 08:07 AM
  #74
Racer944's Avatar
you will definetly be hearing from me in a few years, once i get out of college and get some $
Old 05-03-2005, 10:23 AM
  #75
ok....if you need to email me you can do so.
teamshiftpoint@ev1.net
thanks
William
Old 05-16-2009, 07:28 PM
  #76
Tragic Drive's Avatar
Bump.
Old 05-17-2009, 12:37 AM
  #77
space-junk's Avatar
why did you randomly bump a 4 year old thread??
Old 05-17-2009, 02:26 AM
  #78
rocket's Avatar
It was worth viewing 4 years later.
Old 02-10-2011, 11:33 PM
  #79
tirogers's Avatar
bump
good thread burred way down in 3.4 swaps
Old 04-22-2011, 10:18 AM
  #80
kcorpetti's Avatar
thanks
William
Hey TSP, I'm working on a Auto swap too. Mind if I contact you, even if 6 years later, to ask some questions?
Quick Reply: 3.4 swaps galore. pics of 3 swapped trucks and more.
