3.0 Hot starting issues
Old 01-16-2019, 08:40 AM
bensyota's Avatar
So what was the solution to this?
Old 01-16-2019, 04:27 PM
wallytoo's Avatar
last user activity, 7 years ago. last post in thread, 8 years ago.
good luck.
Old 01-16-2019, 04:47 PM
bensyota's Avatar
good luck.
worth a shot!!!! Lol
Old 02-20-2019, 08:38 AM
DH4runner's Avatar
I was plagued with hot starting for over a year as well and delt with it stalling at idle red lights and stop signs, wouldnt start for over an hour after cooling.. i replaced all my vac hoses because of a vac leek, didnt fix the hot start but helped it run better. Replaced cap/rotor, serviced the entire intake plenum suroudnings, gaskets, hoses, plugs, nothing. found out i had a double missfire, dead injector #1 and a bad distributor, replaced them fwo and no longer unable to hot start!! runs great. Not sure if it was either or that fixed the issue.
94 3.0 3vze 2wd
The following users liked this post:
bensyota (05-01-2023)
Old 05-01-2023, 05:24 AM
  #25
bensyota's Avatar
Originally Posted by DH4runner
I found out i had a double missfire, dead injector #1 and a bad distributor, replaced them fwo and no longer unable to hot start!! runs great. Not sure if it was either or that fixed the issue.
94 3.0 3vze 2wd
how did you find the bad injector?
Team420
01-12-2021 04:57 PM
sonic concepts
07-01-2015 02:33 PM
Alex Bessinger
06-28-2015 10:05 AM
slider417
06-22-2015 10:18 AM
jmc88runner
06-18-2015 03:39 PM
Quick Reply: 3.0 Hot starting issues
