Old 02-10-2016, 09:25 AM
How-Tos on this Topic
Last edit by: IB Advertising
    Print Wikipost
    2nd gen 4runners lift guide
    Old 09-28-2008, 12:09 PM
    SR5
    SR5's Avatar
    ^^^you might want to add BJ spacers up front to help even it out
    looks great other wise
    Old 09-28-2008, 12:17 PM
    SR5
    SR5's Avatar
    pics and specs of more yota!! https://www.yotatech.com/forums/f116...r-yota-155366/
    Old 09-28-2008, 12:21 PM
    woodendude's Avatar
    Originally Posted by crawyota
    here is what I did with my second gen. I got a set of FJ80 rear coils $85.00 , shocks $120 / set , Tires (MAXXIS BIGHORN MT'S 255/85/16) $600.00/ SET , labor / case of beer, and crank the TORSION BARS up front.
    here is the end result
    Like I said in PM you've nailed the look I'm after... The dealer parts guys here haven't a clue though when I asked them for a price on fj80 series rear coils, they what a part number or year. What year/s ere the 80's series land cruisers made and where they marketed in Canada ( these fools can't find it on the computer, neither could the local Parts Source guy)
    Old 09-28-2008, 12:27 PM
    SR5
    SR5's Avatar
    ^^^^ 1990-2008
    http://en.wikipedia.org/wiki/Toyota_...2.80.932008.29
    Old 09-30-2008, 05:19 PM
      #25
    VK Innovations's Avatar
    What lift height did you get your rear shocks for? 2" or 3"?
    That's the only thing I need to know to finish off my lift package
    All new parts minus the 80 series coils.. I'll post the final cost once everything's in. Along with pictures of course!
    Old 09-30-2008, 05:29 PM
      #26
    Matt16's Avatar
    The truck right measures 13.5" from the top of the rim straight up to the bottom of the fender.
    Old 09-30-2008, 05:47 PM
      #27
    sts2usnss's Avatar
    So if I decided to go with the 4Crawler 2" lift using the 1.5" ball join spacers and the 2 inch coil spacers, would I need to change out to a longer shock? Or is anything else needed for that matter?
    Old 09-30-2008, 05:55 PM
      #28
    SR5
    SR5's Avatar
    yes you need their pan hard drop bracket, and you don't need new shocks right away, but you should get them soon, i recommend porcomp es9000s cheap and very good
    Old 09-30-2008, 08:52 PM
      #29
    Marc P's Avatar
    Having owned my 4runner for about 7 years now, I have changed the suspension a few times.....here is my history lesson...
    When I first bought it, Downey was the only game in town...so I purchased some 1.5" HD coils and cranked the torsion bars to match. It had very little flex, but worked ok for the trails I was running.
    Then the ball joint spacers were available from SDORI and I put them on, relaxed the torsion bars to factory specs, and went with 33x10.5 BFG's. It worked great, flexed ok, but the front was a little higher than the rear again.
    I then replaced the rear coils with some FJ80 coils, and added a Panhard drop bracket. It worked good, but the truck leaned a little due to the coils being different lengths (that is how they are). So I bough another set and used both long side coils.
    I ran that setup for quite a while, until the upper control arm bushings gave me issues...I ditched the IFS and completed an axle swap up front. For the rear I have basically the stock configuration with the exception of adjustable upper links, adjustable panhard bar, and OME 860 springs. Eventually I may swap the rear to leaf springs.
    Old 09-30-2008, 08:57 PM
      #30
    fillsrunner4's Avatar
    Hold up... Marlin started his buisness in 94' Downey in the 70's with the owners love of landcruisers yes but Marlin was well in the game 7 years ago
    Your rigs sick and you know it!
    Old 09-30-2008, 09:06 PM
      #31
    Marc P's Avatar
    But Marlin didnt have squat for IFS 4runners.....
    Old 09-30-2008, 09:08 PM
      #32
    SR5
    SR5's Avatar
    good post March
    Old 09-30-2008, 09:18 PM
      #33
    Matt16's Avatar
    Did you experience any idler arm failures at the height shown?
    Old 09-30-2008, 09:27 PM
      #34
    UMMMMM.......
    Your final outcome was a SAS wasnt it???
    Just giving you a hard time! :hilbill:
    Old 09-30-2008, 09:32 PM
      #35
    Marc P's Avatar
    Nope...ran a brace the whole time. I did replace the bushings a couple times.
    Old 10-01-2008, 08:40 AM
      #36
    mlrtime99's Avatar
    Hey Marc, just for the sake of this being an informative thread, do you happen to remember the heights each change gave you? What problems did you have on the upper balljoint, binding/breaking? That was with stock torsion bars at the factory preset and just a 1.5" BJ spacer?
    Old 10-01-2008, 11:03 AM
      #37
    crawyota's Avatar
    Location: CHESTER COUNTY , PA ; by way of KOBLENZ , GERMANY
    Yah , the BJ SPACERS are coming soon , getting them from SDORI.
    Old 10-01-2008, 12:41 PM
      #38
    crawyota's Avatar
    WELL FOR THE COILS I looked on the classifieds of yotatech , and other toyota forums , if you get 1991 - 1997 fj/fjz80 coils they'll fit.
    the shocks i got are for 0-4" lift From ROUGH COUNTRY . I am gonna get a set of BILSTEINS though.
    Old 10-01-2008, 12:58 PM
      #39
    I'm going to get Skyjackers for my setup for the price. They have 0-2" and 3-4"
    Do I go with the 3-4" rear shocks and 2" for the fronts since the BJS's are 1.5" setup?
    Old 10-01-2008, 05:09 PM
      #40
    SR5
    SR5's Avatar
    id do 2" all around
    Quick Reply: 2nd gen 4runners lift guide
