22RE- York on board air COMPLETE - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Old 09-22-2008, 02:49 PM   #1 (permalink)
Matt16's Avatar
I fitted a York OBA system recently. Here it is:
Compressor: Full-sized York off a Volvo (I think, I bought it from a guy who had it in the garage)
Bracket: Adapted from a 22RE A/C bracket, you need a sort of spacer as well
Air lines: 3/8"
Air tank: Air brake tank off a Ford dump truck (note: not a dumpy Ford truck)
Valves switches etc: One-way into the tank, 150psi pressure release valve, drain valve, 90psi on/120psi off
Description:
  • York is belt driven off the engine in place of the stock AC pump (you can't install the York like I have with AC)
  • pressured air goes down the air line, through the one way valve
  • pump has a magnetic clutch that is activated by a relay
  • relay is only thrown when:
    a) the day-time runnning lights are ON (always on when engine is running (Canadian spec)
    b) the switch in the engine bay next to the quick disconnect is ON
    c) pressure is below 90psi.
  • air tank link to quick disconnect zip-tied near battery
  • fills up a 31" tire from ~5 to 35psi in ~30 seconds at 2500rpm
cost estimate
  • York compressor...................<$50
  • 22RE A/C bracket....................$30
  • 25' air hose, cut inot pieces......$15
  • NPT fittings............................$50
  • air brake tank........................$50
  • air filter, pressure valves.........$40
  • electrical bits.........................$50
  • TOTAL................................~$300 (based on what I actually spent)
  • Knowing your compressor pumps out 10X more air and costs less than half of the guys with a Viair....Priceless
more info: http://www.yotatech.com/f116/york-ai...r-22re-152143/
__________________
1990 Toyota 4Runner 22RE 5spd
*Aussie Locker*York OBA*
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Quote:
Originally Posted by DeathCougar View Post
next time when the front of your engine sounds like a can of spoons, fix it
Toyota FAQ link
More info on 4Runners
Matt16 is online now
Sponsored Links
To remove this ad, register today!
Old 09-22-2008, 03:02 PM   #2 (permalink)
littlecommando's Avatar
Send a message via AIM to littlecommando
looks good, i have been thinking about doing this too
do you still have A/C even with the air compressor?
__________________
1985 Toyota 4Runner SR5 4WD red, mostly stock, mossy oak seat covers, custom stereo system, Dixie Horn, Custom Rear Bumper
Build Up
Powder Springs, Georgia
Quote:
Originally Posted by Corey View Post
Once must also realize that YotaTech has always been open to both 2WD and 4WD trucks and SUVs.
This means the gnarliest off road rig, to the lowrider that scrapes its belly over a dime in a parking lot.
While it is true that 4WDs far outnumber the 2WDs here, all are welcome.
littlecommando is online now
Old 09-22-2008, 03:15 PM   #3 (permalink)
Matt16's Avatar
No, I never had AC, just bought the bracket. The York sits where the stock AC would. You would have come up with a complex bracket to make a York work with AC, but I'm sure someone has done it, try searching Pirate BB.
__________________
Toyota FAQ link
Old 09-22-2008, 03:17 PM   #4 (permalink)
scuba's Avatar
You bought a guy ???
lol
lookin good matt, congrats
__________________
GO BOLTS!!
91:THUMPIN TRUCKIN LIFTED AND LOCKED WRECKED
86 2x4In the crusher since 09/08
I have bad luck
Spring Break Much?
http://www.yotatech.com/f15/spring-b...und-up-158664/
Pacific Crawlers
UltimateYota
scuba is offline
Old 09-22-2008, 03:20 PM   #5 (permalink)
Quote:
is this just a trail rig or do you just just suffer through the heat every day?
__________________
Build Up
Old 09-22-2008, 03:21 PM   #6 (permalink)
Matt16's Avatar
Quote:
lol
Someone's got to grease my muffler bearings, and that someone ain't gonna be me.
__________________
Toyota FAQ link
Old 09-22-2008, 03:23 PM   #7 (permalink)
Matt16's Avatar
It's my daily driver. With the windows down, its never too hot in the truck. I'm also in Canada, so heats only an issue from June to August, and even then the hottest I ever remember is 35*C (95*F)
__________________
Toyota FAQ link
Old 09-22-2008, 03:25 PM   #8 (permalink)
Alex 400's Avatar
did how do you hold it at 2500 rpm? did you make any kind of throttle holder mechanism or anything?
something like this...
http://www.madisonpowersystems.com/1...s/throttle.htm
__________________
1994 toyota 4Runner SR5 Limited 4wd, 3.0 V-6 3vze, 5-speed, 31/10.50-15 toyo A/T, Studded Maxxis Bighorns for winter driving. All Pro 1.5" coil springs, Bilstein front shocks, doetsch tech mv12's rears, , MC heavy duty clutch
feasable wish list:
33x10.50 BFG KM2
5.29's's
ARB rear air locker
Future things to do
TC long travel BJ kit.
other ride:2001 Honda XR400R with USD conversion
Quote:
Originally Posted by slisdexia View Post
I blame the automatic transmission for the wussification of America
Alex 400 is online now
Old 09-22-2008, 03:29 PM   #9 (permalink)
that makes since, why bother fixing it for 2 months a year, right?
__________________
Build Up
Old 09-22-2008, 03:41 PM   #10 (permalink)
Matt16's Avatar
I never had AC to start with. I went to a wrecker, bought the AC bracket, used a tap to clean out the thread on the block, and then built a spacer bracket to fit on the AC bracket.
__________________
Toyota FAQ link
Old 09-22-2008, 03:48 PM   #11 (permalink)
I didnt even know that no A/C was even an option
i guss thats a canadan thing?
__________________
Build Up
Old 09-22-2008, 03:55 PM   #12 (permalink)
Alex 400's Avatar
well the sr5 like you and i have, were the top of line (next to the limited) and they came with A/C I don't believe the base models came with it.
__________________
feasable wish list:
33x10.50 BFG KM2
5.29's's
ARB rear air locker
Future things to do
Old 09-22-2008, 03:56 PM   #13 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
A/C was always an option...
Looks good Matt, OBA is awsume, hopfally I can rig something up in my truck in the future..
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Old 09-22-2008, 04:00 PM   #14 (permalink)
Snotrocket's Avatar
Send a message via AIM to Snotrocket
Quote:
My truck never had it either. There are a lot of base model Toyota's around here that don't have it. I can only think of one day all summer I wish I had it. Heat on the other hand........
What is the compressor out of exactly? I've got 3 old Volvo's kicking around.....
__________________
1993 Reg Cab Pickup
22re 5spd
31 inch AT's
Black Interlux paint job
Matching camper shell
Custom interior
Snotrocket is offline
Old 09-22-2008, 04:00 PM   #15 (permalink)
JasonWin's Avatar
My 1985 SR5 doesn't have A/C, and I'm pretty sure it never did, nothing on the dash to sudjest it did.
__________________
Quote:
Originally Posted by toyota-erik View Post
I run big tires because I have a really small penis
Weekend Rig - 85 SR5 Pickup:
4x4, 5-Speed, 22RE
Custom built box with big stepside fenders
31" ETS Trail Masters
About 3" body lift
Pioneer CD player (iPod Controll) with 10" sub woofer
JasonWin is offline
Old 09-22-2008, 04:05 PM   #16 (permalink)
