22re wont start after head gasket
Old 03-01-2006, 05:23 PM
turbdodge's Avatar
Its pretty much all back together besides a few vacuum lines, went to start it and wouldnt start. Made sure it had a good spark, and could smell fuel so pretty sure thats good. Messed with ignition timing alittle bit and got few back fires and figured it was ignition timing. Double checked cam and ignition timing and Im 99% sure its right on. Only thing else I can think of is if the injectors are hooked up in the wrong order, right now #1 cylinder has a white plug while the other 3 are blue. any ideas? thanks!
Attached Thumbnails 22re wont start after head gasket-picture-28-.jpg   22re wont start after head gasket-picture-30-.jpg
Old 03-01-2006, 05:44 PM
SoCal4Running's Avatar
Honestly I would start by finishing with the vacum lines. Then let us know.
Old 03-01-2006, 06:02 PM
turbdodge's Avatar
True, before it gets ran for more than 30 sec all the vacuum will be taken care of. I just want to make sure it is going to run before everything gets put all back together. thanks!
Old 03-02-2006, 12:13 PM
Flash319's Avatar
You must have the vacuum lines hooked up and the intake complete. If the MAF sensor is not hooked up (air box) then it will not run. The engine must see air flow into the engine or it will not start.
Old 03-02-2006, 06:05 PM
subliminaltrips's Avatar
it may be 180 out on the dizzy. maby just a tooth or 2 off
Old 03-02-2006, 06:53 PM
turbdodge's Avatar
k will try after vacuum lines get firgured out. MAP systems are so much easier thanks for every ones input!
Old 03-02-2006, 07:06 PM
PirateFins's Avatar
I'm with subliminal. If you are getting back fires you are most likely 180* out. I speak from experience 2x's. It may look right but it's not. Also check the valve clearence. .08 in .12 ex, had that problem also, the valves were to tight and were not allowing full compression.
Old 03-03-2006, 12:25 PM
turbdodge's Avatar
Im now sure cam timing is right on, I know piston #1 is at TDC and the cam is between the intake and exhuast lobes. I will check the valve clearence tonight.
Old 03-03-2006, 06:30 PM
turbdodge's Avatar
THAT WAS IT! adjusted the valves and it started right up. Thanks again every one. Check out www.turbododge.com sometime
Old 02-22-2015, 08:46 PM
Jbowls's Avatar
ok first off I know this thread is older than my kids... but I was in the same boat after my head gasket replacement. perfect timing, strong spark, I was getting air, still not firing. I reset the valve clearance and viola... started right up. if anyone else reads this post after a head gasket replacement with same issue make sure you check the valve clearance.
An thankyou PirateFins
Old 11-10-2023, 12:20 PM
Meatbag's Avatar
Reviving this from the dead to add my experience as well.
Just finished a headgasket and couldn't get it to start. Ended up needing a valve adjustment! That's it!
ej1618
03-15-2015 09:00 PM
87TOYA22RE
05-01-2010 12:51 PM
Scroff
11-01-2008 08:10 PM
grayguy
04-17-2008 08:26 PM
93bluetoyo
02-23-2008 05:44 PM
Quick Reply: 22re wont start after head gasket
