22re weak or way it is ?
Bonjour! En anglais pour tous le monde.
Going up the hill to Vieux Quebec, maybe?
The 22R engine is 1970s technology. It runs a very long time, is quite durable, but cannot be accused of being either fast or powerful.
My turbo 4Runner was rated at 136hp stock (crank). I have a dyno post around here somewhere with it hitting nearly 180hp at the rear wheels (through an automatic, boys!) as we were playing with boost. Someday I'll be able to spend the $$ to make that a daily reality. In current trim, it's around 160hp at the crank. It's definitely not fast to 60, but acquits itself well with other Toyotas.
Here's some other Toyota folks talking about how slow their trucks are (for your amusement, not that many useful comments. There's a similar thread on Yotatech somewhere too.)
http://www.4x4wire.com/forums/showfl...fpart=all&vc=1
Actual times instead of snarky comments.
http://www.zeroto60times.com/Toyota-0-60-mph-Times.html
1993 Toyota Xtracab SR5 4x4 0-60 mph 11.8 Quarter mile 18.1 (Still a 22re)
1986 Toyota Celica GT-S 0-60 mph 8.5 Quarter mile 16.3 (lots lighter, still a 22re)
So... do a 0-60 run and report back.
BTW, not sure what the ticking sound is you're referring to, but a properly adjusted set of valves will tick (clatter?) at idle on a 22RE. If they're quiet, be afraid - they're too tight.
I put a lift kit, suspension lift on my 22RE 88 pick up (standard cab/bed) and put 30" tires on it. From that point forward, it was like I was constantly towing a boat. (I also have a camper shell and custom workspace in the bed as well (50 lbs worth of stuff). But as it was stated early on, I use the truck to haul cargo, not break land speed records. For its purpose, it works perfectly.
hehe edeslaur my truck have not meet the vieux quebec yet most of the time it is used to play in mud and haul my motocross now i have adjusted the valve to .008 intake and .012 exaust. it was still making lot of noise i read here http://www.toyotanation.com/forum/80...ustment-2.html that the factory setting was at .007 and .011 i done it it look a bit more quiet but very not much i dont know where this sound come from this is a bit anoyying i know somebody that have the same truck with 22re and it run soo smooth and quiet.. i make many search on internet cant find anything could it be the ignition timing that make fire to early ? some say the injector are noisy to.. my chain guard is there no loose in the timing chain any help please ? should i start a new post about it ?
#27
there it is if i remember well this was after 2 hours running time on the highway just to say the motor was at runing temp
Jcrawl94
10
10-24-2015 04:34 PM
