Old 02-09-2016, 10:52 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Problems by Symptom
Print Wikipost
22re turns over but won't start
Old 08-14-2010, 07:28 AM
  #41
Lysmachia's Avatar
Yes let us know what the problem was so we can re-name this thread for better search-ability!
Old 11-03-2022, 01:19 PM
  #42
nothing to fear's Avatar
Tip worked
Took, I read your comment and it worked about testing the cold start timing switch. My truck sat for ages in the yard until I followed your direction. It was easy by putting a mirror down in there with a light and a wire with alligator clips on both ends, going to prong on left side of switch to my positive batt terminal. Thanks man
Originally Posted by thook
Uh.....if it were the timing chain, the symptoms would be qualitatively different. You'd get no compression and the motor would turn slowly as the valves are interfering with cylinder (correction....piston) movement. I doubt you're having this problem.
Could be that your having problems with the cold start system or the idle air valve is not functioning. My guess is the cold start system. Locate the sensors on the front of the motor. There's two.....one green and one brown. The brown one is the timing switch for the cold start. If it goes bad, it won't ground signaling the cold start injector to pulse fuel on start up. So, pull the connector off, run a wire from the ground side (forget which side that is, but there's only two, so only one will work) and to the battery. Make sure the connection is solid. Then, try to fire the truck up. If it still won't start, keep the ground wire connected, pull the cold start injector from the upper air intake manifold (plenum) and see if the injector is pulsing fuel. If not, then the wiring is bad somewhere or the injector has burned out.
Start there and post back. If you don't post back, you will be severly harrassed by the gentleman above. He's gnarly. Don't tempt him.
Old 11-03-2022, 01:51 PM
  #43
JoeS's Avatar
Igniter or coil. I had an open in my distributor magnetic pickup that prevented it from starting.
Crazychris1871
06-27-2016 10:38 AM
Sandman
07-23-2015 08:15 PM
aciorba23
06-29-2015 04:18 PM
Butch35
06-25-2015 07:47 PM
newzingo
06-24-2015 01:50 PM
Quick Reply: 22re turns over but won't start
