| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22re timing issues
#2 (permalink) |
My first thought was to put the distributor on a different tooth, but it sounds like you did that already. You did set the idle speed first right?
#3 (permalink) |
Yep i set the idle first. I did try to jump the distributer a tooth but it goes too far retarded. I can barely get it to 0 degrees like that. It's probably more like 2-3 degrees after tdc with the dist. a tooth off.
#4 (permalink) |
I wonder if maybe the chain is off by a tooth.
#5 (permalink) |
You won't need an adjustable cam gear. After my rebuild I had a total of .018 taken off between the head and block just to get it resurfaced.
But anyway, my timing is dead on and I have plenty of allowable movement on the distributor. How does the motor run? Does it run like it's a tooth off? What's your Idle speed at when your checking the timing? |
#6 (permalink) |
The timing chain is not off a tooth. I checked it 20 times. It seems to run fine although i haven't actually driven it yet. Still need to finish up a few things before a test drive. I set the idle by ear because i dont have a tach. I'd say it's about 800-850 rpm. It idles perfect. I'm getting no codes from the computer.
#7 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
What degree are you actually to get the timing set to?
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
#8 (permalink) |
The lowest i can set it to is 5 degrees btdc but the distributer is fully rotated clock wise. It's hitting the clamp down bolt. I currently have it set at like 10 degrees btdc. Seems to run ok, although i still haven't actually taken it on a test drive yet.
#9 (permalink) |
i just advance mine up to detonation and pull it back a skosh, cave man timing LOL
__________________
85 SR5, 87 SR5 (SAS), 88 DX (on loan), 96 4Runner 2.4L, 96 4Runner 3.4L, all males... and they all RUN! 2003 Chrysler Town and Country LTD... female it runs too :) CLIK4PIX |
#10 (permalink) |
Still haven't figued it out yet but i think i'm getting close. Is there supposed to be a washer in between the cam sprocket and distributer gear that bolts to the cam? I have a 22re so it doesn't have the fuel pump thing that bolts to the cam. My haynes manual shows a washer in between the cam sproket and the drive gear but when i tore down my motor there was no washer in there. It rebuilt halfed assed prior to me owning the truck. Maybe it was left out on the previous rebuild?
#11 (permalink) |
Neither my '88 nor '91 has a 'washer' or spacer between the cam sprocket and distributor drive gear.
You do not EVER want the distributor adjustment max'd out one way or the other... so: If you're rotating the distributor clockwise (looking straight into the top of the distributor), you are retarding the timing... ... turning the distributor counter-clockwise is advancing. The distributor rotor rotates clockwise so if you move the distributor the same direction... logic says that's retarding the timing. 88 22RE manual should be at 5 BTDC (at least mine says so). Pull the distributor out and rotate the rotor 1 tooth counter-clockwise, then install the distributor and rotate the distributor counter clockwise until the distributor has 50% adjustment in both directions. Then start the engine and set the timing.
__________________
Why do people run the dishwasher and walk the dog? I would love to go look but I'm too busy sorting my random coin flip collection.
#12 (permalink) |
That is my whole problem. If i jump the distributer a tooth each way it is maxed out. Either fully retarded or fully advanced. The timing chain and sprokets are set up properly. I've literally checked it 50 times. I'm beginning to hate this truck.
#13 (permalink) |
If the head was machined, there's the possibility that the extra length in the timing chain has put you in that 'nether region' where adjusment isn't possible without an adjustable cam sprocket....
As for me... I'd grab a dremel and open the distributor adjustment 'slot' a bit more so I could make it work.... On the other hand, there is the possibility that advancing the rotor 1/4, 1/2 or 3/4 turns and moving the spark plug wires around the distributor as appropriate could counter the problem...but not likely.
__________________
#14 (permalink) |
The head is a brand new EB head with 261c cam and o/s valves. Block was decked .010. Anyway i just figured it out. I jumped the cam gear back a tooth to retard it and what do you know that was the whole damn problem. I put an adjustable cam gear on after i assembled the motor but before i really got it running. I must of had it a tooth off. Now i have plenty adjustment and it runs fine. I think with the block being decked the cam dowl wont got to 12 o'clock position and that was messing me all up. Not thinking I had to advance it a tooth to get the cam dowl to look right. Anyway who cares it's all good now and i thank you guys for all the input. By the way i have the cam advanced about 3 degrees with the adj cam gear. I'm gonna try 4 or 5 and see how it runs.
#15 (permalink) |
don't go much farther.
The 22re is an interference engine and too much cam advance or retard WILL result in the pistons hitting the valves.
__________________
#16 (permalink) | |
Quote:
that's why i was afraid to start it at first. seems to run great now. next challenge is nj state inspection saturday morning. |
#17 (permalink) |
Went to take it to get inspected today. Never even made it. The truck had no power barely reved to 4k rpm so i turned around and went home. Pulled the valve cover and and the timing marks just didn't look right. I jumped it a tooth advanced and so the cam dowl is at 12 and the crank key way is at 12 just like it originally was. Threw the distributer in and back to square one. I can get the ign. timing down to about 5 degrees btdc with the distributor fully cranked. If i move it 1 tooth either way it wont start or runs like . I currently have it set at 10 and it runs great with no pinging. Anyway i've come to the conclusion that i am either missing a washer/spacer in between the cam sprocket and the distributor cam gear or i have the wrong distributor cam gear . Are they the same for a 22r and a 22re? I know 22r's have some type of spacer thing to drive the fuel pump. Is a 22re a bit longer to compensate for that? I've come up with conclusion because if i space the cam distributor gear out about 1/8 it lines the dist. rotor right up with the pick-up in the distributor. Any ideas? I was told the truck got a new motor about 25k miles ago. I dont know if it was rebuilt or a swap from a donor. When i got it the motor was smoked anyway
#18 (permalink) |
Contact EB with your problem. Dowel pin location may be off in cam since its aftermarket. EB may have had other problems with his supplier. Call him, he is a good man.
#19 (permalink) |
if you bump the distributor shaft 1 tooth clockwise, make sure you turn the distributor just as far clockwise too. if you don't, you've suddenly given yourself over 20 degrees more advance than you had before
__________________
#20 (permalink) | |
I've emailed EB and he said check the timing? I am 1000% positive the timing chain is set up properly. This is straight from LC's site for the adjustable cam gear that i have.
Quote:
If i put the distributor in jumped 1 tooth either way it is either way advanced or way retarded. I am not even able to get the crank pully notch anywhere near the tab on the oil pump when trying to set the timing. Yes the pins are jumped for the computer and the idle drops down so i know my tps is working. This truck is driving me absolutly insane.
#21 (permalink) |
The '88 FSM shows the washer in the diagram on page EM-13. On page EM-17, for the 22re they call it the camshaft thrust plate and for the 22r there is a fuel pump drive cam.
My 85 & 86 22re's have the washer. I'm having a similar issue on my 86, but I have the washer.
__________________
85 Pickup - 4WD, 22RE, stock, Revos, 330K+ |
#22 (permalink) | |
Quote:
Now if i could only get it to pass NJ's emission inspection.
#23 (permalink) |
Location: Nashville, TN PM if I can help. It helps if ppl know your location as well
finally!!
I'm dying here fellas, my RTE is running great at @30° BTDC runs, idles and drives ok, till you hit her hard(advance), driving around 4k rpms and she cuts back. I believe it's b/c the timing parameters are out. I seem to be having some problems similar to you see here: RTE will not idle and left over night seems to start w/ low compression and tick i could use all the help I can, she's about one foot in the grave. I'm about to donate her for the $5 and sledge all you want, or to MythBusters to see what a vehicle looks like after a tank has run it over.... She has only minor surface rust so I'm gonna H8 to see her go...but she's already cost me in thousands in pain and suffering. Oh yeah, and I've put tons of REs together but just can't seem to get this one. all help will be mucho appreciated, THX EDIT** whoops, I bought a cam gear partly b/c of what I herd here. Did you have to degree your cam? or did you just get it close and nail it? How does this look? Last edited by tried4x2signN; 07-06-2008 at 02:44 PM. |
| Tags |
| 20, 22re, adjustable, btdc, cam, checking, degrees, keyway, retard, set, sprocket, straight, timing, tooth, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Timing Issues? | langzaiguy | 86-95 Trucks & 4Runners | 7 | 09-29-2007 03:49 AM |
| Timing issues | mytoy | Newbie Tech Section | 13 | 07-16-2007 11:59 AM |
| 22RE Timing Issues! | SupraSport | 86-95 Trucks & 4Runners | 23 | 01-28-2007 02:04 PM |
| Timing issues... | MarkH1121 | 86-95 Trucks & 4Runners | 8 | 12-05-2006 10:03 AM |
| 22re timing chain/set timing/rtv/headremoval | brendonv | Maintenance & Repair Archives | 4 | 09-20-2005 07:18 AM |
