22re stumbling and check engine code 2
Old 03-28-2016, 04:49 PM
Toyotabc's Avatar
Originally Posted by crawler85
Come again? It shouldn't be running good on 3 cylinders.
It was misfiring a bit and removing the 3rd plug wire it ran almost the same as it did with it plugged it, obviously ran a bit worse but compared to removing the other wires this ran decent
Old 04-01-2016, 07:55 PM
Toyotabc's Avatar
Took 3 of the AFM wires that go directly to the ecu and soldered 3 new wires to eliminate that out of the question. Still nothing.
Found something weird, if I hit my AFM the truck will run poopy at idle, like not a misfire sound but more like a fuel cut sound? Almost wanting to swap another AFM in and see this still happens
Unplugged my injectors one by one and didn't find anything worth noting. No fuel pressure test because I'm to stubborn to think that's the problem LOL
Hoping to find more info out tom as I have some free time this weekend.
Old 04-16-2016, 04:26 PM
Toyotabc's Avatar
Good news!
everything is fixed and going good now.
NO check engine light, timing is within spec all is well!
Grabbed another different ecu and took apart all my wiring splicing and soldered them all back and runs great now! Was obviously a broken wire but had enough strand to show continuity.
Lesson learned for next time don't be lazy and not check everything no matter how much work is involved LOL
Old 04-16-2016, 06:48 PM
osv
osv's Avatar
bad wiring? gee that sure sounds like something that i suggested earlier
congrats on getting it running.
Old 04-16-2016, 07:24 PM
  #25
crawler85's Avatar
NICE!
Nailed it on your first guess!
12
01-18-2016 05:21 AM
LoflandJ
01-13-2016 06:35 AM
killbasser
01-06-2016 02:00 PM
tristan_nemo
01-06-2016 01:44 PM
Ame4Noobs
01-05-2016 04:01 AM
Quick Reply: 22re stumbling and check engine code 2
