22re stumbling and check engine code 2
Old 03-19-2016, 07:06 PM
Toyotabc's Avatar
22re stumbling and check engine code 2 FIXED!
Hi everyone, its my first post on yotatech hope to find out whats wrong with my 22re.
I have a 1987 toyota pickup with a 22r motor. Recently I did a 22r to 22re swap with an 1986 efi donor engine. It seemed to run well till about a few weeks ago. The check engine light would come on for 5-20 seconds and shut off, while the light was on the truck would stumble at idle or at whatever rpm i was at driving at. I checked the code when it first came on and it blinks 2 times which points to the airflow meter. Now I have swapped multiple airflow meters that forsure worked and it still won't stop with the check engine light or the stumbling.
Here's the list of stuff I have checked so far:
Airflow meter(replaced with ones that worked before pulled)
checked the wiring resistance for the airflow meter to see if theres a broken connector and all seemed good
Tried a few ecu's from the same year and the problem came back immediately
Adjusted throttle position sensor
Set timing at 5 degrees with the jumpers on T and E at the diagnostic port
Checked Egr
spark plugs and wires all look normal
Took a stethoscope and checked for vacuum leaks(none was heard)
This problem is driving me nuts and I don't know what else to check for. Any help would be appreciated!
Old 03-23-2016, 06:07 PM
osv
osv's Avatar
the wiring resistance test is better than nothing, but it only needs a strand or two to pass, because the meter isn't putting much current through it.
did you connect all of the grounding points? google it, there are lists of 'em all.
if that's not it, the long shot could be a wiring/connector issue, do you happen to have access to another engine harness?
Old 03-23-2016, 06:15 PM
Toyotabc's Avatar
Yeah I might be able to grab another AFM harness and try it out hopefully soon here. Trucks been a huge pain lately as now my OEM water pump with less than 600km is leaking out of the weap holes already. Almost think it would of been better carbed LOL
Old 03-23-2016, 06:20 PM
osv
osv's Avatar
you'll like the 22re much better than carb'd, once you get it running.
check for all of those ground connections, poor or missing grounds can cause all kinds of weird issues.
Old 03-23-2016, 06:59 PM
Toyotabc's Avatar
Yeah I'll try and check everything on the weekend, thanks for the suggestions. I'll let you know how it goes
Old 03-23-2016, 07:14 PM
crawler85's Avatar
Checked Egr
Check the rubber connectors on each side of the plastic tube for cracks (that connect to AFM and throttle body).
Those are hard to detect, won't make a noise if they are leaking.
Old 03-23-2016, 07:24 PM
Toyotabc's Avatar
Took the rubber off and checked it out and it looked good to go. Also sprayed starting fluid all over and no change, I'll look more when I get time this coming weekend
Old 03-25-2016, 06:04 PM
Toyotabc's Avatar
Just made issues worse somehow...was messing around with my distributor air gap and long story short I set the gap too tight and wrecked that distributor LOL
Next day I go and get another distributor and put it in at TDC compression stroke and the rotor facing #1 spark plug wire and the motor runs like poo. Took a few tries to get the right tooth on the distributor but when I did get it correctly the motor misses at idle and bogs alot. I can't seem to get the timing set below 10degrees.
More annoyed than ever with this motor!
Old 03-25-2016, 06:21 PM
crawler85's Avatar
I recommend taking a step back, ignore the code for now and check the basics.
Do you know your fuel pump pressure?
Good spark?
If you get it running is there a way to keep it at a smooth rpm with your foot on the pedal?
If so, disconnect/reconnect injectors one at a time. There is a notable difference in the engine when you disconnect a good injector.
Old 03-25-2016, 06:23 PM
Toyotabc's Avatar
1100-1500 rpms it runs smooth, any other rpm it misses. I'll try disconnecting the injectors in a few minutes
Edit: Dark as heck already so I will continue more tom!
Old 03-25-2016, 06:25 PM
crawler85's Avatar
Also, is this intermittent or steady now?
Does it occur during open loop and closed loop after warm up?
Old 03-25-2016, 06:26 PM
Toyotabc's Avatar
The misfiring is steady now, it occurs warm or cold
Old 03-26-2016, 05:55 PM
Toyotabc's Avatar
Now after changing out my igniter and coil the timing seems to be at 5degrees jumped and 12 degrees unjumped. The missing at idle has gone away unless I rev it in neutral and a constant rpm above 1200 it will miss. It's driveable right now just not that well.
Injectors seem like a pita to get to.
Did a compression test and was 160 on all 4 cylinders
Might take it into a shop to do a air/fuel reading and see what's going on in more depth...
Old 03-26-2016, 06:15 PM
crawler85's Avatar
For about $30 you can install your own fuel ratio gauge.
Just make sure it is narrow band.
http://www.amazon.com/gp/aw/d/B000FJU8GC/ref=mp_s_a_1_28?qid=1459044765&sr=8-28&pi=AC_SX236_SY340_QL65&keywords=air+fuel+ratio+ gauge
Check your actual fuel pressure yet?
Old 03-26-2016, 06:17 PM
Toyotabc's Avatar
Might bring it to a shop to let them check it, maybe hook a vacuum guage up to it to. Not alot of places will be open tom atleast to get anything done. Took all day to find these igniter and coil
Old 03-27-2016, 04:39 PM
Toyotabc's Avatar
POSSIBLY might have found the issue. My water temp sensor(green plug next go cold start sensor) is measuring out of spec by ALOT. That could be causing the AFM light to come on. I'll be going to the parts store to pick one up and crossing my fingers it fixes it!
Old 03-28-2016, 01:40 PM
Toyotabc's Avatar
Got a new water temp sensor and still no fix. New codes have arrived
Code 5 O2 sensor
Code 7 throttle position sensor
Now the throttle position sensor is out by only 20 ohms on one of the tests and the rest of the pins test good which is strange.
Trying to find a buddy with a fuel pressure gauge to borrow to double check mine
Old 03-28-2016, 02:55 PM
crawler85's Avatar
yeah the water temp sensor should not have caused it.
don't go back to the TPS until you have ruled out everything else.
I had stumbling issues that ended up being a fuel pump putting out 20 psi, about half of the required pressure.
you can still do the quick injector check also in addition to the fuel pump.
Old 03-28-2016, 03:17 PM
Toyotabc's Avatar
Ok so I got my rear in gear and pulled spark plug wires till I found one it ran good without. Number 3 spark plug wire off and the motor seems to run pretty good!
Edit: meant it would run similar to when it was plugged in, if I unplugged other cylinders it was much worse
Old 03-28-2016, 04:43 PM
crawler85's Avatar
Come again? It shouldn't be running good on 3 cylinders.
Quick Reply: 22re stumbling and check engine code 2
