Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
22re--oil cap removed, runs wierd
I was letting my 22re idle and i removed the oil cap. The engine idled down so i put it back on. After i put the cap back on, it idled very irratically and when i would give it gas, it would stall. I turned the engine off and let it sit. I started it back up and ran fine. Is this normal or is something messed with my truck?
__________________
89 toyota 4x4 ex-cab 22re 5 speed header flowmaster 31's |
| Sponsored Links |
#2 (permalink) |
You caused a vacuum leak by allowing the engine to suck air in through the valve cover, normal when you do that.
__________________
DJ 1994 Pickup 22RE, Engnbldr 261 cam, 5 speed. Tires that go around and around... Originally Posted By Fustercluck "Proof that Gangus did not spontaneously generate....he has relatives." Originally Posted By Tacoclimber "My two year old better get a job, soon..." Reply Posted By Oly884 "I hear coal mining is a great career." Myspace |
#3 (permalink) |
That is completely normal. By removing the oil cap, you created a huge vacuum leak.
__________________
1990 Toyota 4Runner 22RE 5spd Rear Aussie Locker [click here for the review] *Nokian Vativa A/T tires* OME suspension* some other stuff, but I tell people its stock |
#4 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
A condsiderable vacuum leak was created by removing the oil cap. That is very normal for that to happen as a result.
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
#5 (permalink) |
hahaha, FIRST!
__________________
#6 (permalink) | |
Yeah, yeah...I's just havin' fun....
__________________
#7 (permalink) | |
Hey um, why are you removing the oil cap while the truck's running to begin with???
That's like, number 5 on my list of things not to do while the truck is running... 1) Don't touch the exhaust 2) Don't stick your fingers near the fan blades 3) Keep lose clothing away from belts 4) Avoid touching possibly bad plug wires 5) DON'T TAKE THE OIL CAP OFF
__________________
91 Pickup, 4wd, 22re, stock suspention, rollin on 31s... for now that is... 287 thousand miles and counting... Linkies: YotaTech photos MySpace Quoties: Quote:
#8 (permalink) |
Here's my personal list.
1.) Don't force moving parts. 2.) All parts that move, should move freely. interpretation 1.) If its stuck its stuck for a reason. making it move will just break it. 2.) lubrication lubrication lubrication |
#9 (permalink) | |
Good assembly guidelines; may just have to adapt those for myself, lol.
__________________
#10 (permalink) | |
Take the oil cap off and throw it away, you dont need that.
May as well drain the oil, dont really need that either. Just extra weight, and without that extra weight, you'll gain like, 400 horsepower!
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts! Quote:
#11 (permalink) | |
Not to mention the gain in fuel economy!! Ooooo.....and that would be the end of blow-by. Hell....I'm taking my whole PCV crap out tomorrow.
__________________
#12 (permalink) | |
![]() DeathCougar, I'm put'n that in my sig if you don't mind, lol.
__________________
#13 (permalink) | |
haha that makes 4 peoples sig lines i am in....that must be some sort of YT record?!
__________________
#14 (permalink) | |
Quote:
__________________
1990 Toyota 4Runner 22RE 5spd Rear Aussie Locker [click here for the review] *Nokian Vativa A/T tires* OME suspension* some other stuff, but I tell people its stock Last edited by Matt16 : 03-31-2008 at 09:20 AM. |
#15 (permalink) | ||
Quote:
__________________
#16 (permalink) | |
Lol well its 4 NOW mr smarty.....Course this coming from Mr. stho sthparkly!
__________________
#17 (permalink) | ||
Quote:
Anyone? Bueller? Bueller?
__________________
