22re idle bounce
Old 04-17-2013, 12:52 AM
owbro's Avatar
22re idle bounce
If I hold it at say 3000 rpm for a bit and then let off, on the way down the idle will briefly stop at 1100 rpm then it drops quickly to 950 rpm for a couple seconds before it rises back up to 1100 rpm and holds. Also when I cold start it it will idle at 2000 rpm. Seems a bit high to me, isn't it?
Old 04-17-2013, 04:20 AM
Staff
Terrys87's Avatar
I have seen the Dashpot cause some similar issues. It can be a little stiff. It is what the black hose with the little filter is connected to in that area. Give it a look over and see if that helps.
Old 04-17-2013, 07:26 AM
owbro's Avatar
I'll take a look, thanks. This morning it idled up to 2500 rpm on a cold start and once it warmed up and the idle dropped it rose again to around 1500 rpm and then the rpm started going up and down rapidly between 1500 and 2000 rpms.
Old 04-17-2013, 07:55 AM
toyota4x4907's Avatar
Check your coolant level
Old 04-17-2013, 09:00 AM
owbro's Avatar
I'll top it off and see if it helps.
Old 04-17-2013, 01:22 PM
owbro's Avatar
[URL="http://http://youtu.be/CtxyBhTlJjk"]
There's a video of it. And here's a video of my other problem.
[URL="http://http://youtu.be/3oQS9mKBemM"]
montanatruck
02-26-2017 07:07 AM
DrZero
18
07-24-2015 11:31 PM
jake_v
07-22-2015 03:17 PM
luckypig44
07-19-2015 11:25 AM
shisha1999
07-13-2015 11:09 PM
Quick Reply: 22re idle bounce
