Old 02-09-2016, 10:50 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical Guides
Print Wikipost
22re ground wire locations - the guide!!!
Old 11-06-2018, 04:22 AM
  #81
ev13wt's Avatar
Additional Info on:
NUMBER 3 GND WIRE
I had this hooked up to the valve cover, which makes no sense. As stated, it GNDs the spark plugs. The head cover is sort of isolated from the rest - no real or good GND connection
This is out of an 3K mile old OEM 22-RE engine spark plug. Notice the pitting. It does look a bit large too, the gap.
Engine is smoother, makes a bit more power maybe. The idle is smoother as well. Will check high idle later when off work. (till now I placed it to the ECU bug where you have to set the timing at 3° or even 2°. https://22reperformance.com/faq-diagnostic-info/ )
Putting new plugs in on the weekend, will report back in 3K miles.
Old 12-23-2018, 06:44 PM
  #82
Allysa Chandler's Avatar
Thank you very much it took me quite a while to get it but i finally got out of that gas station parking lot! Lol
Old 12-23-2018, 11:54 PM
  #83
ev13wt's Avatar
Now check the other ground wires too
Old 07-10-2020, 04:46 AM
  #84
Tyler7777777's Avatar
So I just bought a 93 Pickup w/22R-E and I went to clean the grounds as I've read that they are pretty important and my grounds/wiring seems pretty different... So far I've cleaned the postive & negative battery terminals, Grounds #3 & 4, and the extra ground I have and immediately, headlights are twice as bright. I had 4 error codes before cleaning disconnecting the terminals, now they are all gone (but I've also only driven a couple of miles since resetting the codes)
I intend to replace terminals in near future as recommended.
normally goes to A/C, but instead mine goes directly below it
should I move this one?
for whatever reason this is not an all black wire like other people have
In another post, I read you should replace two ground connectors above the fuse box in the interior (drivers side) . Mine only has one ground in the interior.
to the right of air filter / air flow meter
Not sure why mine would be wired so differently (I understand very little about car electrical) , I know the previous owner had a head unit installed, he also said there was an subwoofer with a built in amp at some point, but the vehicle no longer has it. Not sure if that could be the reason.
So I'm thinking the only ground I should move to the correct spot is #1? does it matter for the other ones? I also do intend to replace the terminals that go on the battery.
Old 07-10-2020, 10:02 PM
  #85
Co_94_PU's Avatar
#1 serves as the ground for the starter, anywhere near it on the block side of the motor mount shouldn't be an issue.
Old 11-24-2020, 12:16 PM
  #86
RAD4Runner's Avatar
Chassis* Ground vs Ground to Battery Negative Post.
Good article on why accessories should be grounded to body* ground, not directly to batt3ry nagative.
https://epicenergy.ca/chassis_grounding/
*On our trucks chassis ground really means body ground = to sheet metal of the body. Not ground to the frame. There is no guaranteed ground to the frame/chassis.
The following 2 users liked this post by RAD4Runner:
2ToyGuy (11-25-2020), old87yota (11-24-2020)
iceman601
50
01-08-2020 11:10 AM
SacRunner
3.4 Swaps
75
03-13-2018 04:20 PM
Stetson_md
02-10-2014 11:07 AM
FUNrunner87
All Other Toyota Swaps
07-08-2013 05:54 PM
ShortyzKustomz
02-12-2012 01:57 PM
Quick Reply: 22re ground wire locations - the guide!!!
