22RE - Factory Cruise Control Setup
Old 06-22-2012, 10:49 AM
hgill's Avatar
My Toyota Pickup is missing Cruise Control and I really would like to add that option as I prefer cruise on long trips. I want to go factory instead of aftermarket solutions.
I was at the junk yard the other weekend and I was able to score a mint 4Runner Steering wheel with all the Cruise Control buttons. It was a easy install to replace my existing steering. Plus, I now have Tilt as well :-)
Based on the FSM, I need the following parts to make this happen.
1. Cruise Control Servo Motor / Actuator
2. Cruise Control ECU
3. Cruise Control Relay
4. Clutch Switch
5. Stop Light Switch
6. Parking Brake Switch
7. Neutral Position Switch
I feel that I can salvage Parts 3-7 from a V6 SR5 Truck in the junk yards, but #1 and #2 might be 22RE specific.
Can someone who has Cruise Control in their 22RE equipped 90's Toyota Truck identify the Toyota P/N for the following:
Thanks.
Link to the Cruise Control FSM: http://www.ncttora.com/fsm/1993/body...10cruiseco.pdf
Old 06-22-2012, 11:58 AM
angrybob's Avatar
On my '87 4Runner, it was a factory option. I thought that the vehicle would come with the same main wire regardless if it had CC or not. I was wrong. At least for my series of vehicles there were two separate harnesses - Total PITA to convert if you have to change harnesses.
My point is to confirm that you have a bunch of pigtails just hanging there waiting to have CC parts plugged in. My *guess* is that you do not....but I don't know either way.
Confirming that is a good first step nonetheless.
Old 06-25-2012, 12:51 PM
hgill's Avatar
This seems rather disappointing. Anybody with a 1989-95 Toyota Pickup bodystyle who has a 22RE and factory cruise. I can figure out the wiring, just need to know the matching
Servo Regulator PN
Cruise Control Computer PN
I noticed that there is no connection between ECU and CC. Its a completely independent system.
Old 08-20-2012, 10:48 PM
benja455's Avatar
Any progress on this? I'm curious if it's possible.
Old 08-20-2012, 10:54 PM
westjohns yota's Avatar
look underneath your dash to see if you have the cruise control pig tails, if you do you cn eleminate all that do a plug and play setup, if everythings there just finishing setting it up
Old 06-08-2022, 07:41 PM
Mike Barnick's Avatar
its NOT all there under the dash it hangs off the harness on drivers side kick panel and in steering colum my 91 2wd has factory cruise so i got all the parts to try to do my 94 i have alot of parts trucks and i dont see one more with the PLUGS yo need to swap the wiring harness as far as i can see
Old 06-09-2022, 12:18 PM
87-4runner's Avatar
It's a 10 year old thread, but I wonder if he got the cruise done?
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
voiddweller
07-15-2015 03:56 PM
skoti89
07-08-2015 12:05 AM
Quick Reply: 22RE - Factory Cruise Control Setup
