22re Cold Idle Adjustment
Old 05-15-2008, 05:09 AM
DanStew's Avatar
I searched for the adjustment on my 22re. One thread there was pics but since it was old, the pics are not available. I am looking to see what adjustment I have to turn to knock down my cold idle to a reasonable level. I know some do go up to 2k normally but i want it lower since it is a new rebuilt motor and it is just too high of RPMs for me. It is an 1989 22re.
Old 05-15-2008, 06:14 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Does it idle normal once it warms up?
You can adjust the idle bypass screw on the throttle body, but that will also affect the warm curb idle. Just turn the large, flat head screw on the TB clockwise until the idles slows to where you want it.
Old 05-15-2008, 07:15 AM
DanStew's Avatar
Yeah the warm idle is fine, it just idles faster than i want for cold weather. I still have to adjust valves, and not sure if that will calm it down, but i am uncomfortable with it running like that in the morning.
Old 05-15-2008, 07:56 AM
abecedarian's Avatar
If you've got the idle-air valve separate from the throttle body, you could machine some type of restrictor out of brass or stainless and insert it into the line that connects to the bottom of the throttle body to limit the total flow.
Old 05-15-2008, 10:02 AM
Flash319's Avatar
Ya you can't do much for the cold idle. Wide open cold (-30C outside) will give about 2500 rpm. The lowest mine have ever been is 1500rpm when it is hot outside (20+ C). After about 2 min it settles down to 8-900.
Old 03-14-2009, 09:41 AM
TOYOTA 1's Avatar
dang i was just wondering this my self lol.
my cold idle is a lil high for my liking, but warm idle is great!
oh well
Old 03-14-2009, 09:54 AM
BoostedRNR's Avatar
I wish mine idled a little high. Mine barely idles when cold and idles a little high when warm. I've been searching for a way to adjust my cold idle, but I haven't found anything either.
Old 02-06-2012, 03:39 PM
captaincaveman's Avatar
you might try plugging in your block heater if your truck has a working one? the warmer block would atleast reduce your cold start ( warm-up) time, that would help a bit
Old 02-06-2012, 04:50 PM
Really, Cap't? You joined in October 2011, made your first post around 5 months later: in February 2012; you chose to reply to a thread which had its last reply in March, 2009... more than two years before you joined?
Old 02-08-2012, 01:43 PM
lol apperently i wasnt looking at the date just the information, i"ll pay attention next time thx!
Old 02-08-2012, 02:19 PM
Buck87's Avatar
Still, a block heater is a good idea. Does anyone have one?
Old 02-08-2012, 05:43 PM
hey, it's not really a problem, so to speak, but if the last post in the thread is over a year old, it's fairly safe to ignore it. It was either fixed or somehow moved into another thread, or maybe the vehicle got sold. I don't know; just a suggestion.
Old 02-09-2012, 07:15 AM
Buck87's Avatar
Abecedarian,
I always enjoy your posts and you observation on the age of this one was right on. I have revived old threads before when I found a solution, so that the next guy who searches and reads it will have an answer. Since I live in a warm climate I learned something from this thread that I was not aware of.
Captaincaveman,
Good job on searching first and not commenting unless you feel you have something worthwhile to add.
Old 02-10-2012, 07:41 AM
we have to use them up here once in awhile, i live in Sarnia, Ontaio, Canada it's not way north but it can get cold, but i can sympathize with DanStew 1700-2000 rpm cold is a bit rough on a fresh rebuild! those block heaters are handy on those really cold nights, if your worried about power consumption i dont think they draw much at all but you could always throw it on a 2 or 3hr timer just before you wake up? Thanks! fellas or ladies if any? lol
Old 02-11-2012, 04:41 PM
1700-2000 when really cold is about right. The most important things are that the oil is rated for the temp and the oil pressure is correct. If it warms up fine, idles down to spec, the timing is correct, and it drives okay while that happens, there's not much else to do with it.
The primary purpose of the block heaters is to keep the coolant from freezing, which will pop out freeze plugs, thus coolant will dump out when the engine runs. Beyond that, not having to wait so long for the coolant to warm up and blow hot air out the vents is a bonus. The coolant will convect (circulate), to a small extent, with a block heater installed- leaving the heater temp control on hot could help.
Anyhow, sometimes it's nice to see information pop up at random intervals.
Alex Bessinger
08-31-2015 09:17 AM
luckypig44
07-19-2015 11:25 AM
kyletbert
07-17-2015 11:39 AM
Jonny246
07-12-2015 04:51 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 22re Cold Idle Adjustment
