22RE 2WD average fuel economy and can it be improved?
Get a lightweight tonneau cover and if you want to be blinging get some lightweight rims, and an e-fan.
You should see a 1-2mpg improvement and better acceleration as well.
Woah... 27 is twice what I get in my 22RE. I've never seen a 2wd Toyota pickup get 27 mpg. In fact, I don't think I've ever seen any pickup get 27 mpg. Amazing.
#26
Originally Posted by TC22RE's sig
...4x4...
Turbocharged/Modified 22RE...
31x10.50 BFG's
31x10.50 BFG's
Like I said, I do have a shell to put on the back. Since 90% of my driving is flat freeway, I doubt the weight wil be a factor. Problem is that the shell has no side windows and it's like driving a windowless van with it on. Luckily I got some to install. I'm also going to make sure the tire pressure is high enough. So far I have about 190mi and the needle is right on the 1/2 mark, but I have to check it officially to know for sure.
#27
I got 29.8mpg on my last trip to charleston, sc. This was with windows up, tailgate down and running on 87 octane gas. I kept a steady 65mph throughout the trip, amazing.
#28
Well, the Toy is my utility commuter. The SVO gets worse mileage and needs premium on top of that and my '68 Mustang might, might get 15mpg. I also swore I would never own another Honda nor a FWD, even if it did get 42mpg like my old '91 Civic.
My goal is just 28mpg, but I actually gave it some effort and only landed 27. If I can do better, darned if I won't try!
You could go turbo.. If you keep your foot out of it... A turbo increases the volumemetric efficiency of your motor... :-)
BTW, a moderate turbo can be done at a moderate price.. :-)
Moderate boost and timing control can prevent the need for premium gas.
#30
27 mpg is really good.. The highest I've gotten is about 22 (4wd).
My junk seems to do best between 55-65mph.. You know, the space age aerodynamics and all...
How do you drive mainly? In town, on the highway? How fast? You could always regear to 3.90 for highway driving... A diff is about $50 and 2 hours of your time to install / give or take.
#31
There was an aftermarket turbo kit "TEC" I think for the 22RTE back in the day. It improved gas mileage (advertised) by 2-3mpg. I can't find the original ad, but it's out on the web somewhere.
To make matters worse, I have to smog this thing. In CA, that means no mods unless they are officialy 50-state legal or can be easily hidden from the tester. AFAIK, there are no 50-state turbos or blowers currently available for 22REs.
I'm going to fill it up today and see how well I've been doing. 45mph up the Grapevine with the trucks is killing me....
#33
And the results are in........I did 29.1mpg as of today. 319mi on 10.95gal. I reduced my A/C useage, short-shifted, and did mostly ~70mph. There was about 40mi of canyon driving in there also. I'm probably not going to break 30 this go around, but if 29 was that easy, 30 is very possible.
#35
I agree... my 3.slow gets around 16-18 city and 20-21 highway.... i drive around 70 miles per day in mostly city traffic...
of course, i have 4WD and dont go very easy on the accel. you should be glad to get 29 in any truck.
#36
Eh, just a little different than a 22RE 2WD.
Dang you guys, I got 24mpg out of my old 180k '89 Mustang 5.0. Then again, I get 24 out of my current Mustang SVO which is a 2.3L turbo :pat:. My folks get 18 out of their worn-out '93 Explorer(4.0L) and it got 21 when it was new.
I'm trying for 30mpg this week in the Toilet.....eh, I mean Toyota. The tires only had between 20 and 25psi on them, so I brought them up to 25 in the rear and 30 on the front(tires rated at 35psi). My solid-sided shell now has full-length slider windows, so puting it on should help on the highway, which will happen as soon as the pass-though rear window goes in.
#40
I got 23.4 in my 4x4, automatic truck on a 70 mph highway trip last weekend. The AC can stay off this time of year, and the air being cooler adds a little extra power for some reason, that someone here can explain, I imagine.
Going to haul a trailer 400 miles tomorrow, that should drop the mileage down a bit.
I understand that tailgate down is worse than up.
