22RE 2WD average fuel economy and can it be improved?
Old 09-18-2006, 06:32 PM
Dirt Driver's Avatar
I just checked the mileage on my '94 pickup 2WD and it came in at 27mpg and change at mostly 65-70mph highway with A/C. The truck has 188,000 mi, but the engine only has about 5000. I know engines get better economy after break in(I'm covered there), but is it possible for me to break 29 or 30mpg? I have to drive 140mi a day and even my tired Mustang SVO 2.3 turbo only gets about 25.
Old 09-18-2006, 06:44 PM
Bumpin' Yota's Avatar
"only gets 25?"....id give my left testicle to get "only" 25 on a regular basis! hehe Dunno but I want to know about break in procedure too, so TTT!
Old 09-18-2006, 07:07 PM
Glenn's Avatar
Yep, drive slower.
Old 09-18-2006, 07:11 PM
AxleIke's Avatar
my engine has about 7k on it.
It gets, on a hwy tank, between 25-26 mpg.
It is possible.
Old 09-18-2006, 07:35 PM
starlord's Avatar
Try this...
Inflate tires(less rolling resistance)
drop weight(seats, woofers, trash, body panels, shell)
lighter wheels(rotating weight)
aerodynamics(front lip, lower ride height, rear spoiler)
better gas(pays off)
make sure you are tuned(plugs, wires, timing, filters, injectors, good airflow...headers/intake)
drive in a tail wind(i got 67 mpg in my 92 civic vx...its designed for fuel economy)
good luck
Old 09-18-2006, 07:42 PM
MMA_Alex's Avatar
yes its possible, for the most part its not worth it. I'd go full synth, and make sure everythings tuned up and just drive it. 27 isnt bad at all! If gas mileage is that much of an issue sell it and buy a metro or something
Old 09-18-2006, 10:12 PM
Originally Posted by starlord
Try this...
1.)Inflate tires(less rolling resistance)
2.)drop weight(seats, woofers, trash, body panels, shell)
3.)lighter wheels(rotating weight)
4.)aerodynamics(front lip, lower ride height, rear spoiler)
5.)better gas(pays off)
6.)make sure you are tuned(plugs, wires, timing, filters, injectors, good airflow...headers/intake)
7.)drive in a tail wind(i got 67 mpg in my 92 civic vx...its designed for fuel economy)
1.) I gotta check that, actually. The tires are brand new and I usually check the pressure when I rotate them.
2.) It's a stock '94 shortbed with the AM/FM/cassette player. Not much to get rid of. Wouldn't a shell actually reduce wind resistance and improve mileage?
3.) Lighter than stock?
4.) Eh......
5.) Arco not so great?
6.) Only thing not new is the plug wires. Cap, rotor, plugs, and engine are all 5000 miles old. Air filter is nice and white.
7.) I've actually had a crosswind on the highway the last few days. Climbing the Gape Vine outta Bakersfield kills the mileage too.
Originally Posted by Glenn
Yep, drive slower.
I've thought of that, but easier said than done. The limit is 70 for most of my drive. I do between 70 and 75 and you'd think I have the truck in reverse with how fast people go by.
Well, the Toy is my utility commuter. The SVO gets worse mileage and needs premium on top of that and my '68 Mustang might, might get 15mpg. I also swore I would never own another Honda nor a FWD, even if it did get 42mpg like my old '91 Civic.
My goal is just 28mpg, but I actually gave it some effort and only landed 27. If I can do better, darned if I won't try!
Old 09-18-2006, 10:28 PM
Elton's Avatar
my 93 22re 4wd got 24mpg with 235s tires
Old 09-19-2006, 03:45 AM
MMA_Alex's Avatar
full synth you should be able to do 28mpg driving the same
Old 09-19-2006, 05:30 AM
jon_7248's Avatar
Drive with a strong tail wind!
Old 09-19-2006, 06:07 AM
curly_c's Avatar
be happy cuz i get 12MPG ALL THE TIME!!!
Old 09-19-2006, 08:51 AM
MMA_Alex's Avatar
lol gotta love that 3.slow!
Old 09-19-2006, 10:26 AM
94SRUNNER's Avatar
What is the condition of your O2 sensor. This is a leading cause for poor gas mileage. I replaced mine with a factory unit (worth the cost, don't bother with
any other brand) and my mileage shot right up.
Old 09-19-2006, 11:17 AM
jon_7248's Avatar
Yea... 12mpg on 3.slow doesnt even sound right for that engine. Unless your towing or something (or maybe fuel quality?).
Old 09-19-2006, 11:19 AM
jon_7248's Avatar
Also, keep in mind areodynamics. Your truck has a bit more drag and isnt as areo as a car. I for one had 22mpg while in my 4runner with 33s if I drive it right, then got the lift and went to 18-19mpg.
Old 09-19-2006, 12:33 PM
trythis's Avatar
Ok what the heck is with the Spoilers? They create drag, how can that be good for fuel economy?
How about putting a lightweight cover over the bed? Vinyl cover? I read that tail gate down is worse than having it up. Is that the principle behind a spoiler? Silly things, I was under the impression the kept your car pressesd on the raod in formula one cars, and were precisly tuned to balance drag vs down force. I see them on cars with front wheel drive and giggle. Why do you need to press your back wheels to the ground at 60 MPH? bah.
Old 09-19-2006, 04:11 PM
Robert m's Avatar
electric fan install, remove rear bumper for wieght, less restrictive exhaust, oh yeah and dont forget to put in a Tornado
anyone know how many gallons does the tank holds?
EDIT: fixed to show more humor.
Old 09-19-2006, 05:23 PM
trythis's Avatar
TORNADO? You have got to be kidding! Do not put that air line restricter into your intake. THose things are not going to improve your economy. Read this:
http://www.popularmechanics.com/auto...s/1802932.html
A quote from the article discussing the tornado and some other similar piece of sheet metal.
THE DYNO SAYS: Both devices reduced peak horsepower by more than 10 percent. The Intake Twister increased fuel consumption by about 20 percent; the TornadoFuelSaver provided no significant change.
Old 09-19-2006, 05:58 PM
MMA_Alex's Avatar
ha i hope you're kidding about the tornado...
Old 09-20-2006, 06:13 AM
Robert m's Avatar
yes i was kidding! thats why it had the "" behind it.
just cause i dont have alot of posts on this forum yet, doesnt mean im a complete noob to cars and trucks.
Quick Reply: 22RE 2WD average fuel economy and can it be improved?
