22RE and 22RE-t Intake/turbo Swap
Old 09-18-2011, 06:38 AM
MYTOYOTA's Avatar
Originally Posted by irab88
they did not label them "22r-et"
and i'm not too sure of how much wiring the 22r actually has
That could be an issue unless you are good with wiring. Depending on the differences you might have to modify or even make your own fuse box.
Old 09-18-2011, 07:38 AM
westjohns yota's Avatar
after completely rebuilding a 22r in an 87, ill say not much wireing lol
Old 09-18-2011, 08:09 AM
irab88's Avatar
all i can think of, as far as wiring, is:
- gauges/sensors
- ignition
- starter
- alternator/battery
- lights
anything else?
Old 09-18-2011, 07:03 PM
Numbchux's Avatar
Originally Posted by jdeeds
I just picked the truck up today and noticed that the motor that the previous owner installed is a 22r not re
You're in deeper than I can help there. I have no concept what would be require to convert that block to FI.
Got your pm, unfortunately, I didn't take many pictures of things, and both toyota motors have gone off to scrap a couple years ago. A Chevy V6 lives in that engine bay now.
When you say "Turbo EFI", are you referring to the part that actually says that on it (upper intake manifold)? or the whole system?
Old 09-19-2011, 05:59 AM
  #25
jdeeds's Avatar
Yes when I say turbo EFI, i mean the throttle body and intake that bolts on to the block. Using the wiring harness that is was stock for the turbo motor. So basically I have installed the long block of the 22r and the EFI system of the 22ret. I am going to purchase new injectors/gaskets and see what happens.
mskalmus
05-28-2017 07:51 AM
coleypull15
11-03-2015 07:41 AM
steve miller
10-10-2015 01:40 AM
deepmarsh
08-06-2015 03:44 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 22RE and 22RE-t Intake/turbo Swap
