22R seems to be rich ?? Advice appreciated
Old 09-12-2011, 04:51 PM
22R88's Avatar
My 1988 22R reg cab seems to be rich. I say this because when it is idling, the fumes are fairly stout. I recently bought this truck back from my neighbors. Before I sold it in 2002 a buddy of mine ( Toyota Tech at the time) did a Timing chain, valve guide and we installed a 286( I think) Competition cam. I know that it was mild cam nothing radical. He also re- jetted the carb. The engine runs fine and starts easy, it just seems to be rich. I checked the the mixture screw and it was a little over six turns out, so I set it to 3 and half turns and tuned it per the manual then set the idle to 750 RPM. It still seems rich. Could something in the carb be bad like a rubber diaphram ? The carb has never had anything done to it other that the jet. I am just hesitant to tear it apart as it runs fine. Any help or tips is greatly appreciated.
Thanks,
22R88
Old 09-15-2011, 03:37 PM
22R88's Avatar
ttt !! Any ideas. I have verified that the choke is 90 degrees up and down.
Old 09-15-2011, 03:46 PM
Kiroshu's Avatar
Sure its not leaking gas anywhere? Whats the timing at? The 22r naturally runs a little rich but so much as to where you can smell gas. Check oil? Gas in the oil? Prob leaking fuel pump diaphram....
nanhodges2733
05-29-2020 03:28 PM
snosurfer
3.4 Swaps
03-29-2016 11:29 AM
tj884Rdlx
08-28-2015 12:04 PM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: 22R seems to be rich ?? Advice appreciated
