22r Oil filter Shoot out
Old 09-14-2013, 02:48 PM
gmack192's Avatar
Originally Posted by combatcarl
I don't see them say anything bad about purolator pure ones, tho, either. I run a PL30001(?) I think, big ol truck filter. No problems here..
DITTO... But then again I change my oil regularly. I have used the FRAM ph8a too.
Old 09-14-2013, 06:24 PM
RSR
RSR's Avatar
For some reason, I completely forgot to mention flow... Flow matters just as much as the 3 listed.
Old 03-17-2016, 06:21 AM
Chevo303's Avatar
Oil filter bypass valve p.s.i.
Funny thing is when you look up a filters spec, the bypass valve psi setting always say either 8psi or 8-11psi except Baldwins b229 (for 22r) says 20psi. I can actually talk to an engineer at Baldwin too.
Old 03-17-2016, 06:28 AM
Chevo303's Avatar
Look up baldwin filters. B229 for 22r. It will say 20psi, then look up any others on their website & their filters say 8psi or 8-11psi. The b229 is a good size filter too. You can even talk to an engineer at Baldwin too. ...
Eggslinger
06-08-2019 03:32 PM
calderp
Engine Swaps
08-16-2016 05:15 PM
dumpster84
04-30-2016 06:03 AM
calderp
07-27-2015 09:58 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: 22r Oil filter Shoot out
