1994 toyota pickup dlx transmission shifts hard while cold.
Old 10-28-2013, 03:10 PM
MattWeb's Avatar
I have 1994 toyota pickup dlx 4wd auto trans. the transmisson shift hard into first and second while cold. when reaches operating temp shifts fine. I changed the At filter kit no changes. any advice?
Old 10-28-2013, 04:21 PM
scope103's Avatar
Check the throttle cable. http://personal.utulsa.edu/~nathan-b...32prelimin.pdf On the A340H, the throttle cable does not set shift points (that's electronic), but how "hard" it shifts. As in, your problem.
Old 10-28-2013, 04:34 PM
MattWeb's Avatar
thanks for link and reply but wouldn't it shift hard all time if it was throttle cable? it only shifts hard into 1st while cold and sometimes 1st-2nd while cold. when get operating temp shifts perfect.
Old 10-29-2013, 03:11 PM
scope103's Avatar
I don't know. But if you check the throttle cable and it's set incorrectly, fix it. If that doesn't make the problem go away, then continue with your diagnosis.
Here's the page with general diagnosis http://personal.utulsa.edu/~nathan-b...30generalt.pdf (listing throttle cable as the first thing to check under "harsh shifting.") The other items are well beyond my personal comfort zone.
Old 10-29-2013, 03:36 PM
MattWeb's Avatar
thanks for reply ill take a look
Old 04-30-2014, 07:32 PM
MountainRider's Avatar
Did you ever find the issue? I'm having the exact same problem, found this on a search. Going to try and adjust throttle cable tomorrow
Old 04-30-2014, 07:43 PM
HighLux's Avatar
Its probably a loose clutchpack that slips until it gets warm....when its cold it slips a little right as it shifts and bangs in gear. When warmed up the packs expand enough to not slip. Talk to a tranny shop about a friction modifier additive. May help.
Could also be a sticky solenoid that doesnt like the cold.
Does it seems to rev a little as it shifts and then clunk into second? dddddwaaaappow.
Old 04-30-2014, 07:51 PM
Highlux... Ya those will next steps thx. I don't recall it revving up before the shift, but I'll pay more attention to it. Just seems to be a hard shift, a good jolt.
Old 05-01-2014, 05:11 PM
MattWeb's Avatar
Never found cause of problem. My suggestion let truck warm up 5 mins or so before driving. I've found that to help some. Also added lucas transmisson additive. but warm that stuff up bc its like goo if not hot.
Old 05-01-2014, 06:08 PM
Thanks for the reply. I checked throttle cable and found it a little long, adjusted but no help, seems that's the fix when trans shifts hard in all gears. The next steps in FSM are beyond me so I might have to pay out some $$$.
Old 05-02-2014, 11:16 AM
MattWeb's Avatar
took mine to transmisson shop they told me that seals and rings could be bad and needed be rebuilt $500 in parts and $1500 labor. not gonna happen found At rebuild kit on Autozone.com for $269.99
Old 06-04-2014, 01:58 PM
MattWeb's Avatar
could this be caused by a faulty torque converter? I am now hearing a rattling noise around the torque converter area?
Old 06-05-2014, 05:50 AM
rustypigeon's Avatar
Hard shifts are generally caused by high line pressure, or a bad accumulator. Your torque converter may be going bad, but I don't think that it is causing your hard shifts.
The fact that yours shifts hard only in 1-2 makes me suspect the valve body.
Does it shift hard on the downshift as well? Does it shift hard from N to D?
Old 02-21-2015, 07:27 PM
arkansasfamily's Avatar
did anybody figure what it is. Mine is doing the same thing, taking it in to the shop next week.
Old 03-07-2015, 09:52 PM
had the filter and fluid changed out. Think it maybe sifting worse. Everyone is saying worn out tranny, probably from no service from previous owners. Lloks likr it will be 3 thousand dollars
6th Gear
19
12-10-2019 07:31 AM
matrad
01-04-2019 03:06 PM
vasinvictor
01-20-2016 12:39 PM
Crazy_Guy97
12
06-24-2015 04:02 PM
94hiluxZE
06-22-2015 10:42 AM
Quick Reply: 1994 toyota pickup dlx transmission shifts hard while cold.
