1993 bad transmission or shift solenoids?
Old 08-06-2013, 02:14 PM
RockyRoad's Avatar
Hi All-
Been enjoying my 93' v6 auto runner for 4-5 years now but now am having a transmission problem. Started after I pulled a boat a couple of miles. It started by lurching when shifted from park to either reverse or drive. A fluid flush and change made it a lot better. Though now if I get on the accelerator, especially when cold and going uphill, it shakes and won't go unless I back off and start slowly. Also was out on a steep dirt road the other day, not yet in 4x4 mode, and it slipped out of gear. If I stopped and went from park back to drive and slowly pushed on the gas, it would go again. This happened twice. So my ? is. Possibly just the shift solenoids or most likely a wrecked tranny? Have not checked on any codes but the check engine light is not on.
Thanks!
Old 08-06-2013, 04:55 PM
scope103's Avatar
The transmission codes are through the O/D Off light (so leave the O/D switch to on, so the light can flash).
http://personal.utulsa.edu/~nathan-b...31diagnosi.pdf
Old 08-07-2013, 10:48 AM
RockyRoad's Avatar
Great! Will check it out. Thanks Scope!
smthwsn357
05-01-2024 07:28 AM
Charecter1
11-06-2023 10:08 AM
mskalmus
05-28-2017 07:51 AM
BeMiceElf
10-10-2015 09:40 PM
mengquis
07-13-2015 10:39 AM
Quick Reply: 1993 bad transmission or shift solenoids?
