Old 02-09-2016, 09:13 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brake Guides
Print Wikipost
1990 4X4 Front rotor replacement
Old 09-09-2010, 03:21 AM
JimD's Avatar
Nathan the link to the '93 service manual no longer works. Do you have a current link?
Old 09-09-2010, 03:24 AM
Fossilized
Staff
dropzone's Avatar
http://ncttora.com/fsm/index.html
this link also has some
Old 09-09-2010, 03:42 AM
JimD's Avatar
Awesome! Thanks!
Old 04-02-2014, 08:40 AM
frankledrew's Avatar
Front Wheel Bearing preload - torque nut with no socket
Some of us are "pros" are without a socket, and the fish scale drag is a good finial test. But get it right first with vicegrips locked across the nut; then vicegrip a 1/2 extension to the GRIPS on the nut - VOILA ! - YOU CAN TORQUE CORRECTLY THE FIRST PRELOAD 43LBS; THEN AFTER THE ALTERNATE CYCLES OF LEFT AND RIGHT TURNING OF THE HUB; LOOSENING REPEATING; TIGHTENING AGAIN TO 43LBS; ROTATE; LOOSEN THEN ROTATE; FINIAL TIGHTEN TO 21LBS.
FOLD AVAILABLE TABS OF THE LOCK-WASHER TO PIN THE PRELOAD TORQUE; TORQUE THE LOCK NUT TO 43 LBS - WORKED PERFECT.
Late year 1989 pickup 4cylinder ST - i did the timing chain replacement with head on - make sure you pull the pan, the pieces of the rail are not just at the bottom, but can glue and accumulate upon the oil pickup intake screen - lowering oil flow and pressure,
Old 04-02-2014, 06:46 PM
  #25
Logger707's Avatar
Back in the day I've done hundreds of wheel bearings on log trucks by feel no fancy tools they average 10-12 thousand miles a month and the only failures were older bearings or lube problems not preload related
voiddweller
19
05-02-2016 09:10 PM
miceal383
06-29-2015 12:27 AM
Iceman4193
06-28-2015 10:30 AM
YotaGreenhorn
06-27-2015 07:00 AM
HBoss
12
07-19-2002 07:30 AM
Quick Reply: 1990 4X4 Front rotor replacement
