1990 4runner 3vze oil cooler ?
Old 08-14-2013, 02:34 PM
rlshulze's Avatar
Doing a rebuild, mechanic ran into metal shavings in oil cooler off of old engine. Part is discontinued 1571065031, tried to buy one, no dice. Have heard you can wash/clean the cooler, but voids the warranty on reman.
Have read you can bypass the cooler w/ an adapter, to a 2nd filter [bypass type filter like Amsoil]
Any thoughts, part numbers, pics, best avenue of approach etc.? Thanks for the assistance
Old 08-14-2013, 03:39 PM
rworegon's Avatar
Looks available here.
Old 08-14-2013, 08:06 PM
Punchy's Avatar
Wow that's bad if metal in the cooler since its after the filter.
You can fill it with WD40 and set overnight and blow it out with compressed air.
Use a tiny pair of needlenose pliers and pull the bypass valve out of the bolt to clean it up or just leave it out all together.
Rockauto has them as well
Old 08-14-2013, 08:07 PM
Punchy's Avatar
oops dbl pst
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
MMA_Alex
25
04-18-2017 05:07 AM
MTLroadierunner
07-06-2015 12:17 PM
HRDC0R19
07-05-2015 06:43 PM
ptb12
07-05-2015 01:49 PM
Quick Reply: 1990 4runner 3vze oil cooler ?
